still leaking stator gasket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-11-2007, 11:10 AM Thread Starter
Uber Member
well have the stator cover seal fixed now... but for some reason i am still leaking from the big cover... any ideas?
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #2 of 7 (permalink) Old 04-11-2007, 11:26 AM
93VN750's Avatar
As long as both mating surfaces were clean, you put a thin coat of gasket maker on both mating surfaces, and the gasket didn't shift when putting on the cover, it shouldn't leak.
Is it one spot or from all around the seam?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 7 (permalink) Old 04-12-2007, 12:42 AM Thread Starter
Uber Member
both surfaces were scraped clean, then degreased. Black gasket maker was used on both sides. It seems to be leaking from near the 2nd bottom bolt from the front... I've tightened a lil more tonight... see if that helps... if not, i wonder if there is just enough "play" where i can pull the cover enough to weasle in a new gasket without a full removal again...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #4 of 7 (permalink) Old 04-12-2007, 05:23 AM
was that one of the bolts that had a sealer on them??
TrashLord is offline
post #5 of 7 (permalink) Old 04-14-2007, 11:29 PM Thread Starter
Uber Member
sealer??!?! i didnt notice any bolts with sealer on them, and i used copper based anti seize...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #6 of 7 (permalink) Old 04-15-2007, 08:36 AM
I've been told by a mechanically inclined friend of mine to use RTV on one side of a gasket only. The reasoning is with it on both sides a paper gasket has the tendency to "squeeze" out when pressure is applied if you use it on both sides. As for sealant on the bolts, if I remember from my stator replacement the longer 3 bolts had a sealer or locktite on them. There is however, no mention of locktite or sealer on the cover bolts in the reassembly instructions of the Clymer manual.
Foxhound is offline
post #7 of 7 (permalink) Old 04-15-2007, 08:52 PM Thread Starter
Uber Member
humm... i could see that.. i still havent taken he for a run yet.. may do so tonight... i still hope i can get it far enough off without removal again to slide in a new gasket
i remeber the loctite on the bolts now... i figured it was just some funky loctite spin off they put on there durring assembly... anyone have a kaw service manual to verify this?
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
