CAM CHAIN TENSIONER WANTED!!! for 750vn - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 08-10-2013, 05:06 PM Thread Starter
Hi,
I have a converted 750vn trike and in need for a Cam Chain Tensioner as I have a ticking sound which I'm told the tensioner needs replacing.
I can get from America but thought I would ask on here if anyone knows or has one for sale.
Any guidance or help would be great.
Cheers
Speiler
blakeinspeil is offline
post #2 of 14 (permalink) Old 08-10-2013, 07:34 PM
Not sure where you are located, but you could rebuilt them with TOC Manufacturing springs and temporarily fix them OR get the manual ones for more money and replace them as many here have for peace of mind.
Manual tensioners from TOC
post #3 of 14 (permalink) Old 08-10-2013, 08:45 PM
Concert connoisseur
wib714's Avatar
or build your own if money is tight like many of us have, link in my sig line on how too for a couple bucks each!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 14 (permalink) Old 08-10-2013, 09:01 PM
Originally Posted by blakeinspeil View Post
Hi,
Cheers
Speiler
There are 2 cam chain tensioners, one for each cylinder. They can be replaced with Kawasaki oem parts, which lasted me only about 10,000 miles, Or you can replaced them with the solid steel TOC tensioners, which is what I did, after the oem replacements failed. They have lasted over 50,000 miles. You can rig the automatic tensioners to make manual ones out of them, but I don't trust the weak cast aluminum housings. New springs won't likely do any good, as it is the internal threads in the aluminum housing that wear, allowing the plunger to back out. I thought about leaving the automatic tensioners alone, tightening them with a small screwdriver till the noise went away, then put longer cap bolts in them to press on the little screw and keep it from backing out. It might work. I never got around to trying it, I just decided to be done with the problem once and for all, and got the TOC units. I am VERY happy with them.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 14 (permalink) Old 08-11-2013, 09:12 AM
Concert connoisseur
wib714's Avatar
x2 on replacing the springs, they will not last. one of my toc springs broke in just a couple hundred miles. their manual setup for a hundred bucks a pair is the way to go
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #6 of 14 (permalink) Old 08-11-2013, 05:34 PM Thread Starter
Steel TOC Tensioners
hey...!
Thanks for all the feed back guys, sounds like solid steel TOC tensioners is the way forward like what VN750Rider/Jerry said.
Where would I get them from?
Many thanks
post #7 of 14 (permalink) Old 08-11-2013, 05:41 PM Thread Starter
Its ok...
I have found the website.
Cheers again.
post #8 of 14 (permalink) Old 08-11-2013, 05:42 PM Thread Starter
Thanks for taking the time in writing that useful information.
post #9 of 14 (permalink) Old 08-11-2013, 05:42 PM
post #10 of 14 (permalink) Old 08-11-2013, 06:59 PM
emtdon's Avatar
Hi,
Cheers
Speiler
would love to see pictures of you're conversion.
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
