tired black boots - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-09-2013, 08:42 PM Thread Starter
good times
little ugs's Avatar
tired black boots
knock from rear cly., oil blow back and dripping from uni's, (filter), on rear cly., blown rear head gasket? probably obvious as oil drip on floor, not much, blown carb. boot,(manifold)?, smoked oil too from left pipe........oops. any fixes,? need motor? or can I get whats wrong done for less.
little ugs is offline
post #2 of 12 (permalink) Old 08-09-2013, 09:10 PM
No one is going to be able to help you if they can't understand what you are trying to ask. Please try to use complete sentences and we'll see if we can make heads or tails of the situation.
post #3 of 12 (permalink) Old 08-09-2013, 09:57 PM Thread Starter
good times
little ugs's Avatar
sorry man, it looks like a blown rear manifold, isn't that what they call the rubber boot on the carb.? blew oil back into the uni, foam pod style filter and the filter is dripping. rear cylinder was knocking a little before not a cam chain thing I don't believe
post #4 of 12 (permalink) Old 08-09-2013, 10:52 PM
Hmmm... There shouldn't be oil in carbs. Unless you have blown out piston rings. The carb boot would be massive air leaks and really bad running condition. Could be a blown head gasket but usually that would cause overheating first. Someone with better diagnostic skills will chime in.
post #5 of 12 (permalink) Old 08-09-2013, 11:41 PM Thread Starter
good times
little ugs's Avatar
kind of my thinking too, things were going great then a little psst and smoke and I was close so I pulled right in and got off and oil was dripping from the pod air filter and the carb. boot look like it was leaking and dirty too. thanks for getting back, it was kind of wild
post #6 of 12 (permalink) Old 08-10-2013, 12:01 AM
It's called a rubber boot! One of those goes bad, highly unlikely. Definitly would not have oil come back good nor bad ever! Oil coming back, sounds like the rings are fried, try a compression check!
Rebel13 is offline
post #7 of 12 (permalink) Old 08-10-2013, 12:01 AM
Broke an oil line?
wmsonta is offline
post #8 of 12 (permalink) Old 08-10-2013, 09:07 AM
nopickles98's Avatar
Originally Posted by wmsonta View Post
Broke an oil line?
X2
shooting oil directly on (outside of) filter & carb??
seems more likely than oil coming back thru the carb if it was still running at all.
compression check never hurt anybody though, especially with the miles you got on that beast.
I don't wanna pickle......
I just wanna ride my motorsickle.
Arlo Guthrie
http://www.youtube.com/watch?v=g266Uwp6ZnI
'98 VN750
purchased Nov 2012 w/ <8,000mi
previous plate (last time on the road legally) 2002 therefore.......
carb rebuild
AGM & Iridiums
R/R relocation
Kury voltmeter
Splines lubed & in excellent shape
Aug 2013 - new Shinko 230 TM oversized front & rear
Finally got'er shaved
nopickles98 is offline
post #9 of 12 (permalink) Old 08-10-2013, 10:41 AM Thread Starter
good times
little ugs's Avatar
ringer
i'm thinking rings rear cyl. The oil is really all over that carb and dripping from that carb.'s filter only....52K miles seems early for engine overhaul but hey that's what it looks like. thanks for you guys getting back... preciate ugs
post #10 of 12 (permalink) Old 08-10-2013, 02:00 PM
Guess if your carb boot was leaking, oil could get all over the outside of the carb, if that's what you mean. pull one of the rear plugs - if it's filthy with oil, you know where to start. 52K could be a lot if you don't know how well POs took care of it....it's a lot of miles if the oil was changed only 2 or 3 times, or the coolant wasn't checked and overheated a few times.
Arlo Guthrie
'98 VN750
carb rebuild
AGM & Iridiums
R/R relocation
Kury voltmeter
