engine oil filter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 04-10-2007, 10:43 AM Thread Starter
Rider on the Storm
EasyRector's Avatar
Question engine oil filter
I purchased some Purolator PL14610 PureONE Oil Filters from Amazon -- $8.48 for a 2-pack, which I thought was a good price. The only problem is that they are BLUE. I think I heard someone say that they paint such filters black before installing. Is that true? If so, does one simply use spray paint for metal, or some kind of Rustoleum spray?
EZC
EasyRector is offline
post #2 of 14 (permalink) Old 04-10-2007, 11:02 AM
fergy's Avatar
You could probably use anything you want to paint them, since they will only be on there for a while. I left mine blue and it does stand out!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 14 (permalink) Old 04-10-2007, 02:01 PM
Tcat1000's Avatar
Pureolator Pure One filter paint
Here's what ya need to paint those blue Purolator PL14610 filters black. If you have a Sherwin Williams store in your area, go there & buy "Sherwin Williams" part # 140-0514 in a spray can. It's called Wrought Iron Flat Black. It is a perfect match for the filter to match the bike. It is also an exterior rust control paint & looks great on the bike. I just did mine. It is also a very--- -very fast drying finish. It is an "Acrylic Enamel" paint.
Set the filter (gasket side down of course) on a clean paper towel & spray a few coats on it all at once & let it dry.
I just cannot believe that anyone would put that pretty blue Pure One filter on their bike with a flashy chrome label without painting it!
I won't mention any names though............
Tcat............
2006 VN750
Splines lubed With TSMOLY 70
R&R Relocated
Marbled (Cat's eyes no less)
Digital Volt, Amp, Temp gauge (Kisan)
Pipes Drilled
Carb Adj. at 3 3/4
Polaris AGM Battery (190 CCA)
Kaw rear rack
Kaw front engine guard
National Cycle Street Shield EX W/S
Mobile 1 MX4T 10W40 oil (Now labled 4T Racing)
Purolator PL14610 oil filter (Painted)
Iridium Spark Plugs
Pulsating Brake Light (Kisan)
My Motto: Don't get mad, just get even. Trust me, I will get even!
Tcat1000 is offline
post #4 of 14 (permalink) Old 04-10-2007, 02:18 PM
93VN750's Avatar
Guilty as charged......
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 14 (permalink) Old 04-10-2007, 02:22 PM
fergy's Avatar
It goes really nicely with a blue bike. Mine's black! Doh!
I think I have some flat black rustoleum that I might drag out and paint my remaining two new blue ones...
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #6 of 14 (permalink) Old 04-10-2007, 02:31 PM
tankist's Avatar
Send a message via Skype™ to tankist
think about it: you don't see your filter when you ride so the of-color just can't bother you. and if you fin'd yourself looking at the bike and bothered by colored filter the solution is simple - just hop on it and ride somewhere!
so if you ask me as long as the filter does what it suposed to do i personnaly don't care at all what color it is - black, blue, red or whatever.
and if i absolutley needed to change it's color i would definetly just spray paint it as filter is jst temporary item.
good luck.
Ride Safe
Anton.
tankist is online now
post #7 of 14 (permalink) Old 04-10-2007, 04:15 PM
you can do what i did and that is buy a wheel chrome center cap from summit racing supply which should just fit over the filter. the way i attached it is with a magnet. the magnet holds the cap to the filter and it is easy to remove when changing. so i could care less what color it is and IMHO a bike can never have enough chrome.
ride safe, J
free wheel-e is offline
post #8 of 14 (permalink) Old 04-10-2007, 05:12 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
Thumbs up color coordinated
Perfect! Thanks!
Of course, I could also paint it to match my tank... Candy Persimmon Red!!!
EZC
post #9 of 14 (permalink) Old 04-10-2007, 05:16 PM
Benjammin'
BSkaggs513's Avatar
And....the magnet traps metal particles in your filter that may be floating around in your oil system. Brilliant!!!!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #10 of 14 (permalink) Old 04-10-2007, 07:11 PM
Uber Member
i left mine blue... doesnt bother me that much.... i may worry about it when the bike is in a pearl marron and white.... then i may have to do something...
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
