Preparing the bike for a long ride - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 08-09-2013, 02:04 AM Thread Starter
I'm planning on a long motorcycle ride (long for me at least) out west next year...about 3000 miles. So, I'm wanting to make the bike as reliable as possible.
The bike is a 2002 VN750 with 13,xxx miles on it. I'll probably put a couple thousand more miles on it between now and then.
I just cleaned the carbs, replaced the float needle valves, and rebuilt the fuel petcock.
I have ordered the MCCT parts from TOC. The engine runs great but I think the cam chains are starting to make a little noise.
Before I leave on the ride, I plan to replace the tires and the battery to ensure that they don't give me any problems while I'm gone.
Of course, I'll change the oil with Rotella synthetic, new oil filter, and probably put NGK Iridium plugs in it before leaving.
Anything else that I should check/test/replace before heading out?
vulcanguy is offline
post #2 of 24 (permalink) Old 08-09-2013, 05:19 AM
Ndr
Doing the "tuxedo mod" might be a good idea. Or if your willing to take the time and money over the winter to do the TOC side cover mod. Both amount to pretty much the same thing. Once either mod is done, you can swap out the stator without having to pull the engine from the frame. It might even be wise to preemptively swap out you factory stator for a Tim Parrott rewound stator as they are far more reliable. Also, I would swap out to a Mosfet R/R to pare with the new stator.
While your current parts may be in fine working condition, It's my opinion that swapping theses out now would be a good choice rather then having a surprise later in the middle of your trip.
Ndr is offline
post #3 of 24 (permalink) Old 08-09-2013, 08:36 AM
x2 ....NDR, you took the thoughts right out my my head !
vulcanguy -Suggest also, when performing the Tuxedo Stator Mod (TOC or cut your own) I suggest replacing your Dampers....6 Dampers=$40.00
My dampers went out @ 13K+ miles. I have seen others with similar mileage Dampers going out.
TPE Stator & Mosfet - definitely WTG.
post #4 of 24 (permalink) Old 08-09-2013, 09:22 AM
If the bike runs good and battery charges....gas it up and go!! have a good time and don't fix what isn't broken.....just my opinion.
Maybe carry a tire patch kit and some seafoam for the fuel with you. Sounds like you got most of it taken care of to me.
If you go and start monkeying around with stuff that is working fine, then you open yourself up to the possibility of actually creating a problem.
I agree that if you HAVE to split the case to do the stator, you might as well do the mod and change out other things for preventative maintenance while you have it open.
I know it sucks to have to split the case to change a bad stator, but why do the mod until you actually have a problem?
post #5 of 24 (permalink) Old 08-09-2013, 09:29 AM
I carry tire plugs.
post #6 of 24 (permalink) Old 08-09-2013, 09:30 AM
No case splitting required for Tuxedo Stator Mod or Damper replacement....just an engine pull.
post #7 of 24 (permalink) Old 08-09-2013, 10:04 AM
I would make sure to lube the splines, check the fork oil, test the specific gravity of the coolant, repack the wheel bearings and neck bearings, and make sure you put at least 200 miles onto the bike after the maintenance before you hit the road... nothing like finding out that you did all this stuff just to get about 100 miles from town and something that you worked on failed.
post #8 of 24 (permalink) Old 08-09-2013, 10:18 AM
I'll add ....Lube all your cables. Put Ride On in the tires. Cell phone and credit cards, cash..... Then GO.....
A GPS might be handy to have. Some visor/windscreen cleaner and a few flannel towels.
I think pulling the motor for "preventive maintanance" is insane.
If you trust the bike to go 50 miles you should trust it to go 3000.....
post #9 of 24 (permalink) Old 08-09-2013, 12:26 PM
someone told me the bearings are sealed....is that not true?
post #10 of 24 (permalink) Old 08-09-2013, 01:02 PM
It is true. No need to do this, although some fresh grease in the speedometer drive on the hub can't hurt.
Unless you suspect a problem, not sure about greasing the steering head bearings either....the bikes only got 13,000 miles on it, not sure of the regular interval on that.
My point here is if you have been maintaining the bike the WAY YOU ARE SUPPOSED TO, there shouldn't be any need to do anything simply because you're going to ride it farther.....
