squealing sound near the left front, dampers maybe? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-08-2013, 10:16 PM Thread Starter
emtdon's Avatar
the squealing sound can be heard when moving and at idle when given throttle. does the dampers make a noise when they go bad? almost sounds like a chirp. didn't notice any black particles last oil change, but very small metal shavings but not a lot of them
i searched but couldn't find anything.
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 9 (permalink) Old 08-08-2013, 11:00 PM
Dampers are rubber grommet shaped rubbers installed on (1/4") nubs of balance Cam...(the rubber) insulating Balance Cam from Balance gear, thus, by design reducing engine vibration.
Definitely not a source of squealing/chirping.
When my Dampers went out (@ 13+K miles) , first I knew (the nubs broke off-balance Gear worked it's way off) a scrapping/grinding like type noise which became louder over a 30 second time frame. Game over.
too late mate !
post #3 of 9 (permalink) Old 08-09-2013, 01:37 AM
R/R = Relocated Redneck
Jakzen's Avatar
If you just let it idle does it squeal?
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #4 of 9 (permalink) Old 08-09-2013, 07:27 AM Thread Starter
emtdon's Avatar
it does it while riding but doesn't matter what speed.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 9 (permalink) Old 08-09-2013, 08:59 AM
Jakzen's Avatar
If it does it while standing still and giving it throttle, I would do a sound check. Use a long screwdriver or if you have one, a mechanics stethoscope and put the end on various areas and see what you've got. Make sure you check the gas cap and air filter housings (if they're still there).
Worst case scenario, put the business end of the screwdriver in your ear. You won't be able to hear the sound after that (or anything else for that matter...)
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
post #6 of 9 (permalink) Old 08-09-2013, 09:27 AM
Definitely a worthwhile investment with your bike issue !
...available @ Automotive Part Stores.
post #7 of 9 (permalink) Old 08-09-2013, 09:33 AM
I fear you might be hearing the balancer gear slowly chewing away your case from the inside.
I would drain the oil and see what you get. if there is ANY aluminum shavings it is a BAD sign.
Better to fix it now before you wind up having to replace the case and other items.
post #8 of 9 (permalink) Old 08-09-2013, 09:48 AM
Bad sign - Yes ! You would also find rubber pieces.
If you DO find this with an Oil change = DO NOT RUN ENGINE !
Pull engine - replace 6 Dampers = $40.00 (+ gaskets).
post #9 of 9 (permalink) Old 08-09-2013, 10:44 AM
Chirp? I would check the spark plugs. 'Chirp' generally = compression.
wmsonta is offline
