Question about goat belly - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 08-08-2013, 05:33 PM Thread Starter
Been reading the verses about removing the belly or relocating the rectifier. From what I read the front and rear exhaust goes into a muffler under the bike? I have only had my vn750 for a month ,so I went to take a look at mine. My front cylinder exhaust leaves the right side and goes straight to rear of bike. Rear leaves left side and does the same. independent pipes. There is a stamping on the pipes reading 'Kawasaki exhaust.....noise rating etc. then at the rear is a logo reading "Sanke " serial number 2232. Mine is a 1993 VN750A. Are these aftermarket pipes? Should I need to rejet? I am getting 55MPG on the 60 mph highways.
smltownr is offline
post #2 of 22 (permalink) Old 08-08-2013, 05:37 PM
I think it all stock. Mess with it and you will be getting 40 mpg.
post #3 of 22 (permalink) Old 08-08-2013, 05:53 PM Thread Starter
My main question was the confusing about the term 'goat belly' does both pipes go into a common muffler that needs to be removed to not over heat the rectifier? And if so, why on my bike there is two separate pipes with nothing under the battery / rectifier. So, I would not need to relocate the rectifier??
smltownr is offline
post #4 of 22 (permalink) Old 08-08-2013, 05:55 PM
We will need a pic.
BTW welcome.
post #5 of 22 (permalink) Old 08-08-2013, 06:17 PM
unless you look from underneath, you wont be able to see if the pipes got into the belly. actually, its more like the belly connects the 2 sides
post #6 of 22 (permalink) Old 08-08-2013, 06:35 PM
Some folks have done "Goatectomies" removing the goats belly but keeping the stock exhaust. This likely what was done to your bike if your sure theres no chamber above the swing arm connecting the two exhausts.
post #7 of 22 (permalink) Old 08-08-2013, 06:48 PM Thread Starter
Had to have 5 replies to list photobucket address for pictures
smltownr is offline
post #8 of 22 (permalink) Old 08-08-2013, 06:52 PM Thread Starter
Here are the pics....Now I see, above the centerstand. I guess I will be relocating the rectifier. http://s1277.photobucket.com/
smltownr is offline
post #9 of 22 (permalink) Old 08-08-2013, 07:20 PM
that just links back to Photobucket Home Page
post #10 of 22 (permalink) Old 08-08-2013, 07:32 PM
Can you use the (Go Advanced) below and then (manage attachments)
