ACCT Woes: I think Orleans is a cousin to Tirrell's bike... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 04-08-2007, 10:26 AM Thread Starter
Crobins365's Avatar
One discovery after another. THought I had stripped threads on the right ACCT on Orleans after I couldn't cinch down the end bolt. Free Wheel-ie was kind enough to send me a replacement, on which I loaded the spring last night. Looked at the Olreans' ACCT (left in pic) and Free Wheel-ie's ACCT (right in pic) and thought, "Hmmm...Orleans' has the new TOC spring in it; too bad I apparently stripped the threads." Looked more closely at the bolts, and realized that the old ACCT bolt had been jury-rigged - "Hey, it's a little long, but a washer in there oughta do it." What the--?? The previous owner did the same thing with the throttle cables - just added washers as the cables stretched.
Lesson learned: sometimes the problem isn't all that complicated.
C
Crobins365 is offline
post #2 of 2 (permalink) Old 04-08-2007, 11:52 AM
Spriddle's Avatar
glad you got it fixed. those end cap bolts are really really easy to strip if your not careful. I stripped one completely that had been semi stripped by last owner. But its also easy to re-thread. I found stove bolts that matched perfectly to the acct at local hardware store. Fixed it all up ,then got the mcct's.
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
