correct coolant for 1993 vn 750? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-04-2013, 11:59 AM Thread Starter
JES
my bike just decided to leak a small amount of coolant in the floor,not running hot,what should i do as maintenence to the system and what kind of coolant should i use?
JES is offline
post #2 of 4 (permalink) Old 08-04-2013, 12:51 PM
Standard coolant that is acceptable for use with an aluminium block.
post #3 of 4 (permalink) Old 08-04-2013, 04:08 PM
2000 VN 750 Senior Member
If you are unsure or if it has been some time since the system was flushed you should do so but first check for any leaks and check hoses and thermostat. Replace anything that is questionable or leaking. Flush the system fully and refill using the correct antifreeze/coolant as mentioned above.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #4 of 4 (permalink) Old 08-04-2013, 05:11 PM
First find the leak. Don't put any kind of stop leak in it, it will ruin the water pump seal. And don't use DexCool. I've seen a lot of GM car engines destroyed by it. I use Maxima Coolanol. It's green glycol specifically for motorcycles, without silicates. I also tried Engine Ice. It works, but I prefer glycol. With Engine Ice, it takes longer for the engine to warm up in the morning, then when you park it, it cools down faster than glycol, requiring the engine to be warmed up again. But during regular riding, the engine runs just as hot as it does with glycol.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
