Install of new Ape MCCT's - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-01-2007, 06:40 PM Thread Starter
Spriddle's Avatar
Post from last week,on another thread:
I thought about making my own too but opted for a set of Ape's I should be getting tommorrow. I cant believe how poorly the stock acct's are made.
I bought my bike with 800 miles on it and the tapping noise. Tryed the gambo trick with no luck. Took the acct apart and rewound the spring 4 times. After alot of swearing I got it back together only to have the retainer pop off just before reinstalling it on the bike. No I didnt strech the retainer,yes it was in the groove,and yes the open end was between the slots. After alot more swearing, got it rewound and back together. Checked the action on the plunger,when it is all the way out it puts alot of stress on the retainer. enough to bend it slightly (this is at 4 turns on the spring). decided it was safe to put back on the bike figuring that the plunger would not be fully extended when installed. Took it for a ride,noise is gone and it runs better then ever, timing must have been off before. However after seeing how unreliable these are and frustrating to work on I think the manual cct is the way to go.
For a $113.00 Dollars its one more thing (could be a big thing) I dont have to worry about anymore.
New post:
hoping this may be helpful to someone.installed my new Ape MCCT's.
Takes about 20 mins each to install and adjust,easy and straight forward. Bike sounds and runs better then ever.
HAD ONE PROBLEM WITH INSTALL. The mcct's are longer then stock acct's. this is no problem with the front cylinder left side. However,the rear cylinder right side is a problem. THe Mcct is about 3/4 of an inch to long for the coolant expansion tank.My solution was to heat the area of the expansion tank slightly with a torch and work this area with the rounded end of a wrench till I had enough clearance.
Worked great,the expansion tank is thick plastic and I heated it many times and worked slowly. You cant see this area of the tank and alls good.
one more thing, My bikes a 2005,the web sites say that the mcct's are for ?/2003 cant remember the beginning year.But I think that all years would have the same problem I had. BTW,the mcct's are ape KT1100 part number.
Hope this helps someone.
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #2 of 8 (permalink) Old 04-01-2007, 06:58 PM
HAWK
Ccspinner's Avatar
good info. I just got new speings for mine. I have only put in one so far, the front cylender was the only one making noise so I did it. Now I can hear noise from the rear. have to do that one next.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 8 (permalink) Old 04-01-2007, 06:59 PM
for those considering the APE cct's, when ordering them let them know you want one cct about a 1/2 inch shorter and they will cut it to the correct length for you
free wheel-e is offline
post #4 of 8 (permalink) Old 09-04-2007, 08:12 PM
APE MCCT's
Free -- I called today to order a set of their MCCT's and talked to someone named Mike...He said they wouldn't do this, cut the rear shorter. He did say that if I could come up with a name of someone that they did it for, then they would copy that order for me.
If your still around, let me know if they did this for you or if you know the name of who they did it for -- Thanks Greatly!!
Leo
leozimm is offline
post #5 of 8 (permalink) Old 09-04-2007, 10:41 PM Thread Starter
Spriddle's Avatar
You can cut it down yourself if you want.
I would use a dremel or any high speed rotary tool.
Then get yourself two nuts and thread them on the cut down cct.
Back the lower nut tight against the top nut and you have a new bolt head for adjustment.
2005 vn750
idle plugs,marbled
Spriddle is offline
post #6 of 8 (permalink) Old 09-05-2007, 12:56 PM
Mcct
Someone else mentioned TOC MCCT's in the forums and I emailed him late last night and he responded last night. That alone made me a buyer of the TOC brand.
He also stated that they don't have the fitting issue that APE does.
leozimm is offline
post #7 of 8 (permalink) Old 09-23-2007, 10:08 PM
no cutting required on the TOC MCCT's.......just installed them.
leozimm is offline
post #8 of 8 (permalink) Old 09-23-2007, 10:27 PM Thread Starter
Spriddle's Avatar
Yep,I would go with TOC's also. When I bought the Ape mcct's and started this thread TOC wasnt making them.
2005 vn750
idle plugs,marbled
Spriddle is offline
