Cooling Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-29-2007, 05:38 PM Thread Starter
Cooling Problem
I am not a mechanic which will be obvious by my questions. I just started riding my new (well, new to me) 97 Vulcan 750 and this past Sunday, I noticed that it was overheating according to the gauge. The tach never worked and I thought the temp gauge was not functional either. For the two days previous, the fan would run for a few seconds after I quit riding and shutoff pretty quickly after I shut the bike down. On Sunday, I noticed the fan no longer would run. Anytime I would start up the bike it would overheat fairly quickly but the fan never ran again. The previous owner said that the guage was messed up and the bike shop he took it to said it was not overheated and the gauge was wrong.
Anyway, upon advice from a friend, I got a jumper wire and connected it to the disconnected connector from the cooling fan thermo switch to see if the fan would run if I bypassed the switch. It did. Now my friend wants me to test to see if the radiator is grounded by using an ohmmeter by using the lead to the nut that attaches the switch to the radiator and the other lead to a grounded area. He said if the meter showing connection that it is grounded.
Anyone have ideas if it could be something else?
L8nliferydr is offline
post #2 of 9 (permalink) Old 03-29-2007, 06:09 PM
fergy's Avatar
Someone correct me if I'm wrong, but that sounds like a good test for a shorted sending unit. It's not uncommon for the fan switch to get corroded and short out, mainly because of constant splash up and road grime.
Your post doesn't say where you are, but if you're running hot, and the weather is not too warm yet, I'd be checking your entire cooling system. You don't want to run these bikes hot. It will damage your stator which is no fun.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 9 (permalink) Old 03-29-2007, 09:25 PM
HAWK
Ccspinner's Avatar
When was the last time you flushed the coolent system?
I would also check the sending unit.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 9 (permalink) Old 03-29-2007, 09:36 PM Thread Starter
I just got the bike two weeks ago. Last weekend the bike was running fine, the fan was running, and it was not overheating. I believe the temp gauge is working properly. Does that mean the sending unit is working properly?
I used an ohmmeter, touching the connecting bolt of the fan switch and a gounding point and the meter showed continuity. I was going to drain the radiator and remove the switch and run the test it shows in the Clymer. What do you think?
post #5 of 9 (permalink) Old 03-29-2007, 09:40 PM
HAWK
Ccspinner's Avatar
You can test the sending unit without draining the radiator. as long as the temp is where is should be, not hot the reading should be the same as if it is out.
Chad Falstad "Hawk"
Vroc #17649
post #6 of 9 (permalink) Old 03-29-2007, 10:12 PM Thread Starter
I could not find directions on testing the sending unit. Do you have a link?
post #7 of 9 (permalink) Old 03-29-2007, 11:42 PM
HAWK
Ccspinner's Avatar
I have it in the Clymers manual page 338. States that at room temp there should be no continuity between the 2 contacts. Put the sensor in hot water 201-212 F do not get the plug wet just up to the threads and should read 0.5 ohms.
If you run the motor you will get the same results as removing and heating in a pot of water/coolent mix.
Chad Falstad "Hawk"
Vroc #17649
post #8 of 9 (permalink) Old 03-30-2007, 12:27 AM
Here's some resistance #'s from the Kawi service manual....
post #9 of 9 (permalink) Old 03-30-2007, 07:07 AM Thread Starter
Thanks to CCspinner and hyper. I will work on it this Saturday!
