Thermostat purchase - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 07-30-2013, 07:29 AM Thread Starter
chiller's Avatar
Thermostat purchase
Anyone know where I can get a t-stat replacement for a good price? $35 seems a bit steep at Cheapcycleparts.
Thanks ahead of time.
chiller is offline
post #2 of 22 (permalink) Old 07-30-2013, 07:43 AM
JM2001's Avatar
You can do a search here. Some have used a thermostat for a 1989-1999 Honda Civic with good results.
WRONG info. It's for a Honda Accord. See link
https://www.vn750.com/forum/showthrea...nda+thermostat
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 22 (permalink) Old 07-31-2013, 05:27 AM Thread Starter
chiller's Avatar
Thanks JM!.
chiller is offline
post #4 of 22 (permalink) Old 08-01-2013, 04:57 AM Thread Starter
chiller's Avatar
Put in a t-stat for a 1985 Honda Accord, 1.8 liter engine...$9.99. Good fit, works well. Curious thing, the actual working mechanism of the t-stat is offset in the housing. Didn't affect anything though.
I got the Super Stant t-stat which, if it fails, it fails in the 'open' position.
Thanks again for the help guys!
chiller is offline
post #5 of 22 (permalink) Old 08-01-2013, 07:24 AM
JM2001's Avatar
Good info. Glad it fit. Can you give us info as to what your temperature readings are now. I'm thinking of putting that thermostat in my bike.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 22 (permalink) Old 08-02-2013, 05:11 AM Thread Starter
chiller's Avatar
Will do. Riding to work today and will get info. Weather has been crappy lately so have only logged a short ride or two.
chiller is offline
post #7 of 22 (permalink) Old 08-02-2013, 07:11 AM
JM2001's Avatar
Thanks Chiller
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 22 (permalink) Old 08-02-2013, 07:05 PM Thread Starter
chiller's Avatar
Rode into work at 57 this morning. Temp gauge needle didn't get to the thermometer stencil on the gauge. Driving home at 83 it never moved past the center of the thermometer stencile...sooo...I'm pleased with the setup. If I had to do over, I'd prolly get a 160 t-stat (if available). Reason being that the fan comes on at 180. It doesn't come on while at speed...say over 60 but runs a lot in town. My LED volt meter tells me so which is only more stress on the charging system while the fan runs....and as you know...we have a very fragile charging system.
chiller is offline
post #9 of 22 (permalink) Old 08-03-2013, 07:54 AM
JM2001's Avatar
Thanks Chiller, I'm going to get the 160 degree thermostat to try and reduce the number of times the fan comes on.
http://www.autozone.com/autozone/par...832_1640_93208
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 22 (permalink) Old 08-03-2013, 09:37 AM Thread Starter
chiller's Avatar
A 160 will definitely do that...
Autozone has one for $19.95...part number 7240-160
chiller is offline
