Custom made pipes with internal baffles - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-27-2013, 11:58 PM Thread Starter
I am thinking about making some pipes and putting in some 8 inch or 12 inch baffles in the stock diameter pipes. Similar to the ones in the pictures.
ID:	9625   Click image for larger version
yamahondakawi is offline
post #2 of 10 (permalink) Old 07-28-2013, 12:01 AM Thread Starter
I was wondering if this could cause any problems and If I could run it without rejetting for awhile.
post #3 of 10 (permalink) Old 07-28-2013, 12:10 AM
R/R = Relocated Redneck
Jakzen's Avatar
What have you done with the intake? How restrictive would the baffles be?
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #4 of 10 (permalink) Old 07-28-2013, 12:13 AM Thread Starter
The intake is stock and the baffles would just be universal bolt on ones from like jp cycles.
post #5 of 10 (permalink) Old 07-28-2013, 12:16 AM
Jakzen's Avatar
You might be alright. I'd run it for a little while and check the spark plugs to see what's going on.
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
post #6 of 10 (permalink) Old 07-28-2013, 12:19 AM Thread Starter
The only thing is I would be cutting and welding the pipes so if it didn't work out I would be sol.
post #7 of 10 (permalink) Old 07-28-2013, 12:34 AM
Jakzen's Avatar
These motors are like any other, nothing more than an air pump. You can't push out any more than you pull in. With the restrictive stock intake, changing the exhaust is going to have a limited effect. With stock style baffles, you should be ok, but check those plugs. They'll tell you if you're running too rich or too lean.
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
post #8 of 10 (permalink) Old 07-28-2013, 12:49 AM Thread Starter
I'm looking at some 8 inch drag specialties ones. The smallest part of the pipe is 3/4 of an inch.
post #9 of 10 (permalink) Old 07-28-2013, 12:50 AM Thread Starter
Like these.
post #10 of 10 (permalink) Old 07-28-2013, 01:41 AM
Jakzen's Avatar
That pic doesn't really say much about how restrictive it is. You gotta look down the pipe to get a better idea. Are you leaving the goat belly in?
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
