Oil System Modification - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 40 (permalink) Old 03-21-2007, 09:12 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
Something I have been thinking about and thought I'd pose the question to the experts in here.
We all know keeping our stator cool is paramount to keeping it around and functioning like its supposed to. And, changing the oil frequently is one way to make sure it does stays cool. Has anyone considered adding an oil cooler to our bikes to help keep that temperature down? Is it even possible? I had an air cooled bike from the early 80's that had a small, factory oil cooler fin mounted behind the forks, and pumped oil through it to keep oil temperatures relatively manageable. If it can be done, that (and a MF battery) would be the perfect solution to our potential stator problems!
With some of the incredable modifications I heard about in here, has anyone done this yet?
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #2 of 40 (permalink) Old 03-21-2007, 09:44 PM
Rubline's Avatar
I wouldnt think it would be that much of a problem. Although the external oil lines are very small diameter. Some how you would need to tap into the lines, and run it through a radiator. My old 77 KZ 1000 had an external oil cooler mounted on the front of the frame.
Rubline is offline
post #3 of 40 (permalink) Old 03-21-2007, 10:14 PM
Sky Rider's Avatar
I don't imagine it would be too hard. The oil line modification would probably be the hardest part. Mounting a separate radiator wouldn't be too hard as one could modify a transmission oil cooler from UHaul or the like.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 40 (permalink) Old 03-21-2007, 10:38 PM
Drive less, ride more...
theauhawk's Avatar
An oil cooler for our bike was discussed in an earlier forum at:
https://www.vn750.com/forum/showthrea...light=pressure
But if someone can offer up some better suggestions than were given there, then hey, go for it!!!.....
theauhawk is offline
post #5 of 40 (permalink) Old 03-21-2007, 11:28 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
Oil Cooler
I found an oil filter adapter on eBay at this link;
http://cgi.ebay.com/ebaymotors/Honda...QQcmdZViewItem
If the link doesn't work, search for this item number; 220007341390
Does this fit our bikes? It uses 20mmX1.5 threads on the filter, which, according to the description, is a Fram PH6017A. I believe this is the filter for our bikes, is it not?
Maybe, just maybe something already exists to help us out?
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
post #6 of 40 (permalink) Old 03-22-2007, 05:19 AM
The only thing I see that might be difficult with that would be if there's enough room at the oil filter location to screw that on. If it's not too tight of a fit, the brass oil line fittings could be removed, the adaptor installed, then the fittings put back on (and hopefully pointing in a usable direction)
post #7 of 40 (permalink) Old 03-22-2007, 02:52 PM
EDALBRIS's Avatar
This Is Almost Exactly What Mt Old Z1000 Had On It As Standard Exept The Oil Lines Pushed In And Had A Small Screw To Hold Them In Place But It Would Not Be A Problem To Alter The Fittings On This One (if They Where In The Way) So They Wern't In The Way.
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #8 of 40 (permalink) Old 03-22-2007, 03:08 PM
EDALBRIS's Avatar
Also You Can Fitt A Finned Aluninium Cover Around The Oil Fillter That Pushes On To Make It Act Like An Oil Cooler, I Know They Are Available For Some Bikes Already , Also Some Harley's, But Would Be Easy To Make/have Made As A Custom Item.
EDALBRIS
EDALBRIS is offline
post #9 of 40 (permalink) Old 03-22-2007, 03:15 PM
Uber Member
this is the next step once summer comes about to see if its really needed. i will measure oil temps on hot days, both sitting and running on hot days (live in dallas, 100+ is common). Right now here is all that will be needed
1) a low resistance oil radiator
2) oil filter adaptor and relocator
3) appropriate oil line material (rubber or steel braded)
4) Bypass on the lines to cut out the oil radiator.
5) depending on mounting location, possiably another fan
Cost is around $400 for that set up using quality parts. Worth it if its really needed. Also moves the oil filter, i know i've already lost 2 to rocks.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #10 of 40 (permalink) Old 03-22-2007, 03:15 PM
EDALBRIS's Avatar
Check This Out http://www.cyclecountry.com/manuals/...ll%20Sheet.pdf
AT http://www.cyclecountry.com/products/showPage.asp?id=90
EDALBRIS
EDALBRIS is offline
