Oil drip stator cover - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-15-2013, 07:49 PM Thread Starter
wicker san antonio
Just got my motor back in after replacing damaged stator cover. The very bottom bolt is dripping, about a drop every5 mins or so. Tightening the bolt did not help. I was able to get a small spanner on the bolt and back it out about 5/16 in. I have cleaned it off with carb cleaner and then lacquer thinner. Looking for a recommended thread sealant that someone has used in a similar application.
Thanks,
Wicker, San Antonio
PS for future ref, recommend anyone working on the stator , put the oil back before moving the engine back into the frame. At least 1 quart which showed my leak. And yes I did torque the bolts to book specs.
wwicker:
wwicker is offline
post #2 of 4 (permalink) Old 07-15-2013, 08:49 PM
use RTV Silicone
post #3 of 4 (permalink) Old 07-15-2013, 08:57 PM
I personally like using Permatex Ultra Copper (101BR) Silicone on aluminum parts, but thats just me....I use Permatex Blue on steel (Copper on heads though).
post #4 of 4 (permalink) Old 07-15-2013, 11:31 PM
SlowBox's Avatar
Right stuff.
SlowBox is offline
