ACCT replacement on front cylinder - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-14-2007, 12:07 PM Thread Starter
What is best way to get the oil line bracket off and then back on to the screw holding in ACCT on front cylinder??
njeagles is offline
post #2 of 10 (permalink) Old 03-14-2007, 12:20 PM
I just use a long pliers to bend the tab out of the way and then bend it back when I was done.
JamieB is offline
post #3 of 10 (permalink) Old 03-14-2007, 02:17 PM
Be careful if you try to bend that tab back inplace. It's kinda flimsy, and with too much bending can break.
I, as well as others, have just kept it bent and didn't worry about remounting it. The oil line is pretty sturdy there, so I don't see it being a problem.
post #4 of 10 (permalink) Old 03-14-2007, 09:33 PM
Sky Rider's Avatar
I just manhandled it out of the way without bending it. Of course I invented some new cuss words along the way but I got the ACCT off and back on again with no problems. That was before I knew about this group.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #5 of 10 (permalink) Old 03-14-2007, 10:26 PM
Crobins365's Avatar
I did what Hyper told me to do - bent it out of the way, and just left it there. Have had to pull the ACCT again recently, so am just as happy that I didn't bother bending it back in place.
C
Crobins365 is offline
post #6 of 10 (permalink) Old 03-15-2007, 04:35 PM
I have bent it twice without problems. Second time I put new springs so hopefully I won't have to do it again.
JamieB is offline
post #7 of 10 (permalink) Old 03-15-2007, 04:56 PM
93VN750's Avatar
Yup, bent it out of the way with a right angle needle nose. Bent it back when done, twice so far without any issue.
Only bend as little as needed to avoid stressing the metal.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #8 of 10 (permalink) Old 03-15-2007, 05:20 PM
Uber Member
i wonder if anyone makes some chrome clams that we can replace that with... i'll have too look around. I know we have some at work that are just stainless, but if they were chrome, then it would be perfect.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 10 (permalink) Old 03-15-2007, 09:00 PM
93VN750's Avatar
Please let us know if you do, and where they can be gotten from.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #10 of 10 (permalink) Old 03-16-2007, 02:59 AM
On the one Gathering vid, with Beavis doing an ACCT rebuild, he mentions just bolting a small L bracket to the oil line bracket once it's straightened out. Granted, you'd then need to unbolt two things to remove the ACCT. He also mentions just leaving it bent out of the way.
As far as clamps, you'd possibly need to grind away the weld from the bracket that's attached to the oil line, unless you can cut the bracket extremely close to the line.
