front cylinder and tach not working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-13-2007, 07:58 PM Thread Starter
Bartman's Avatar
went to go for a ride this evening and had a hard time starting the bike, when I finally got it running the tach wasn't working and the front cylinder wasn't firing. Any suggestions as to what to look for???
thanks
Bart
Road Captain
SCRC Valdosta,Ga #274
VROC #19066
Wet Butt Riders #253355-2
PGR
Bartman is offline
post #2 of 4 (permalink) Old 03-14-2007, 12:08 PM
fergy's Avatar
I believe the tach is wired to the wiring for the front coil. I'd look there to start with. Sounds like something has come loose or is shorted.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 4 (permalink) Old 03-14-2007, 03:56 PM Thread Starter
Bartman's Avatar
I believe I have shorted pick up coils........does the engine have to be removed to replace them????
Road Captain
VROC #19066
PGR
Bartman is offline
post #4 of 4 (permalink) Old 03-14-2007, 09:41 PM
Sky Rider's Avatar
The book will say yes. However, if you are good with a soldering iron and don't mind a little splicing inside the stator area, you can get away with not pulling the engine. There is a thread from 2-3 months ago where someone thought their pickup coils were shot and a lot of advice was put in there on how to do it without pulling the engine.
Here is the link.
https://www.vn750.com/forum/showthrea...ght=pick+coils
Hope this helps. BTW, IIRC, it turned out the pick u coils weren't the problem here after all. That may help as well.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
