Torque Settings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-13-2007, 04:39 PM Thread Starter
Rubline's Avatar
Torque Settings
Will the torque settings change if I have a 6 inch extension or a universal socket at the end of a torque wrench? Will I have to compensate ?
Rubline is offline
post #2 of 6 (permalink) Old 03-13-2007, 04:42 PM
93VN750's Avatar
I don't know by how much, but both the extension and the universal will alter the readings. Perhaps Tim may have a hard answer for you.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 6 (permalink) Old 03-13-2007, 04:47 PM
HAWK
Ccspinner's Avatar
It should make no difference, Only if you have a offset like a crow foot on the wrench.
That is out of a Toyota manual.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 6 (permalink) Old 03-14-2007, 04:04 AM
I agree with Chad. Shouldn't make much difference.
What ya could do is, find a nut/bolt that will fit the socket with the extention and/or universal, but does not need either of those to reach it.
Check the torque with, then without, and see if ya get a noticable difference. That way you'll know for sure.
post #5 of 6 (permalink) Old 03-16-2007, 04:46 PM
fergy's Avatar
Ya know, that's a good idea Hyper! Wouldn't have thought of that.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 6 (permalink) Old 03-16-2007, 05:26 PM
Uber Member
the extension shouldnt make a difference so long as its not a cheapie one where you can get almost 45 degs of play of of it. The universal might make a minor though if the bolt/nut isnt directly in the middle. Keep in mind tourqe is measured in ft*lbs. that means using a 1 ft handle, how ever many lbs you apply to it. so the moment you adjust that length, the ratio changes.
EX)
25 ft*lbs using an 18 inch long ratchet means at the handle there is 16 2/3 lbs on the handle of force. so if your extension give you an added inch of play in length, then things change a lil. added inch of play brings tourqe on the nut to 26.38 lbs.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
