Bought The V and H Pipes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 07-13-2013, 05:12 PM Thread Starter
Mod
Birdhunter02's Avatar
So, picked up the Vance and Hines pipes on e-bay earlier and they look great! Chrome is good and shined up fantastic. They are going to look really nice on the ride. The only problem is two of the three brackets are broken on the chrome heat shield. The PO just used clamps on the outside to attach them to the pipes. Not liking that at all.
Any chance of welding new ones without affecting the chrome? Maybe mig or solder? Just needs a thin strip of metal for the clamp to go around.
Also, anyone know the correct jets for these puppys? They are the cruzers.
Birdhunter02 is offline
post #2 of 16 (permalink) Old 07-13-2013, 05:14 PM
With the stock intake you should not have to rejet. You may need to adjust your AF mixture screws to 2-2.5 turns out from 0. I don't know about welding the tabs, but that's a shame.
post #3 of 16 (permalink) Old 07-13-2013, 06:09 PM
...jb weld the bracket back on the inside of the heat shield. Can't wait to see those bad boys on your bike.
post #4 of 16 (permalink) Old 07-13-2013, 07:09 PM
or you could leave the sheilds off and wrap the pipes back to the muffs
post #5 of 16 (permalink) Old 07-13-2013, 07:15 PM
Attach needed strips with chrome plated fancy hardware?
wmsonta is offline
post #6 of 16 (permalink) Old 07-17-2013, 07:20 PM Thread Starter
Mod
So called V and H. They suggest the main jet to be 135, shim needle valve 1mm and fuel-air 2 1/3 turns. Help M Angel...
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
post #7 of 16 (permalink) Old 07-17-2013, 08:21 PM
I like it, should do good job.
wmsonta is offline
post #8 of 16 (permalink) Old 07-18-2013, 05:51 AM
Lol... I'm the default SE Michigan mechanic. C'mon man its not super hard to do, but taking the carbs out and putting them back is a pain. Changing jets is easy and shims aren't bad either.
post #9 of 16 (permalink) Old 07-18-2013, 07:43 AM
Ask Mercury to send you the money to put the bike on a dyno before doing any jettting............
post #10 of 16 (permalink) Old 07-18-2013, 09:23 AM
or Merc can rent you his "still" to hook up and test the mixture
/S
