air filters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-09-2007, 01:20 PM Thread Starter
air filters
I was planning on de-winterizing the bike this weekend and thought that I would clean the air filters out. What do I need to clean them out with and do they need to be oiled afterwards? If so what type of oil and how much?
Also, after fogging the engine I couldn't get it to rev above 4000 rpms and after doing some searches I think its due to the carb vent hose. Does anybody have a picture of where this is suppose to go?
DougFunnie13 is offline
post #2 of 5 (permalink) Old 03-09-2007, 03:15 PM
"ya can't live forever"
artman's Avatar
Right side air filter in the hole in the back towaed the rear. Cut the end of the hose at a 45 degree angle to keep it from being clogged up.
artman is offline
post #3 of 5 (permalink) Old 03-09-2007, 09:38 PM
Sky Rider's Avatar
If you have the stock air filters, a simple cleaning with warm soapy water and once dry you can re oil them using 30 weight oil. The other route is to buy a K&N filter recharge kit and use their cleaner and re oil spray. That's what I used for mine.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 5 (permalink) Old 03-10-2007, 02:24 AM
And be sure the filter are completely dry after washing!! <(added that at edit)
The only thing I don't like about using motor oil is, it is always going to have a tendency to drain to the bottom (especially on non-absorbing filter materials), where as a filter specific oil is quite sticky and stays in place better.
post #5 of 5 (permalink) Old 03-12-2007, 04:45 PM Thread Starter
Thanks for the input guys...i went and bought the k&n cleaining kit and it worked great. Also found that vent hose and cut it at a 45 degrees and it ran much better. Amazing that one hose can cause the bike to run so poorly! Thanks again.
