Removing the Spark Plug Retainer - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-04-2007, 11:19 PM Thread Starter
predente's Avatar
Question Removing the Spark Plug Retainer
What do you use to remove the spark plug retainer aka cylinder head plug?
predente is offline
post #2 of 9 (permalink) Old 03-05-2007, 06:14 AM
Crobins365's Avatar
You're talking about the retainer that has the two o-rings on it? with the 27mm ID? I looked high and low for even just a bolt that I could put in there, but to no avail. So I pulled the castle nut (left side) off the rear axle and used that. It's a perfect fit - just there's not much of a wall in the ring against which to seat the nut. So find your angle and tread carefully. The rings are aluminum and easy to score if you pull the nut too many times while trying to pull the ring. Once you find the angle, though, you'll be fine.
C
Crobins365 is offline
post #3 of 9 (permalink) Old 03-05-2007, 06:32 AM
Thats what I used too...but I loaded my socket with a paper towel so I would have some push to hold it in there.
TrashLord is offline
post #4 of 9 (permalink) Old 03-05-2007, 06:40 AM
Crobins365's Avatar
Great idea - hadn't thought of that!
C
post #5 of 9 (permalink) Old 03-06-2007, 12:56 PM
I made one out of a large dowel, but the second time I tried to use it the wood gave way. Glad to know about the castle nut. I will try that next time.
stacks is offline
post #6 of 9 (permalink) Old 03-09-2007, 09:42 PM
Sky Rider's Avatar
I found a bolt with a 27mm head and used that. Had to go to a specialty shop that carries about any threaded fastener known to man. It cost about $2-3 or so if I remember right.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #7 of 9 (permalink) Old 03-10-2007, 02:18 AM
Some FYI on this.....
27mm is very close to 1-1/16in
27mm=1.0629"
1-1/16=1.0625"
The difference (.0004") is less than 1/10 the thickness of an average human hair (.004"),
so if 1-1/16" is all you can find, it'll work just as good.
post #8 of 9 (permalink) Old 03-10-2007, 06:08 AM
Crobins365's Avatar
27mm=1.0629"
1-1/16=1.0625"
Darn it! Taken in by the metric system once again! Thanks, Hyper - I imagine finding a 1 1/16 nut is whole lot easier.
C
post #9 of 9 (permalink) Old 03-10-2007, 07:03 PM
Let's hope so !!
