VN 750 Motor Noise _Vulcan 2001 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-08-2013, 09:57 AM Thread Starter
Hippo Daddy's Avatar
Bought the bike 6 weeks ago now. Just over 9K miles. Runs great. Upgraded to iridium plugs and did full oil and filter change. 42 MPG with every tank.
Noise started in front of engine. Cackling. I have read about this on the forum, and have read what to do about it. My questions is simple: If I do nothing... is this going to get worse?
I have a 600 mile round trip planned in the next ten days and was planning on driving the bike from Kansas City, MO to Cedar Rapids, Iowa. I have never driven anybike on this type of trip before and felt this was the first bike that I have ever owned that could handle it... now I am not so confident.
No noise when idling. No noise in most of the gears. Does not happen every time. Annoying more than anything.
Can this bike handle the trip?
Something I should do before the trip?
Should I pass on driving the bike?
NORMALLY.. would this bike be ok for a long trip like this?
Thank you for your comments in advance... I value the forums opinions.
Hippo Daddy is offline
post #2 of 7 (permalink) Old 07-08-2013, 10:52 AM
It's likely your front cam chain adjuster.
Search - Grambo Trick
If its intermitant not sure if be too worried about it, but I'm not there to hear it and tell how loud it is.
If its really noticable when you first start the bike (when cold) but seems to go away after the bike warms up...I wouldn't worry
If it seems just as loud when the bikes warmed up, I'd try doing something about it before you leave.
post #3 of 7 (permalink) Old 07-08-2013, 11:54 AM
Okiebezer's Avatar
^ x2
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #4 of 7 (permalink) Old 07-08-2013, 12:35 PM
Just a regular guy
Chris32250's Avatar
Agreed, if its the accts, I let mine stay noisy till it became a persistent steady noise... then converted to manual ones. I would think about changing them before the trip, but that's just me.
Make sure your rectifier is relocated before such a long trip... otherwise it may not get enough air and if it overheats your bike will no linger charge the battery... it happened to me on just a 200 mile trip.
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #5 of 7 (permalink) Old 07-08-2013, 12:36 PM
x3 on the ACCTs. I'd just get manual ones and get it over with. The ACCT is such a bad design in our bikes that I consider them a ticking time-bomb, waiting to destroy the engine.
post #6 of 7 (permalink) Old 07-14-2013, 11:14 AM
Mod
Birdhunter02's Avatar
Alittle off subject, but would you still need to relocate the rectifier if you degoat the beast?
Birdhunter02 is offline
post #7 of 7 (permalink) Old 07-14-2013, 11:38 AM
No, but it wouldn't hurt...Relocating R/R is still cooler.
