Installing aftermarket exhaust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-03-2007, 07:04 AM Thread Starter
Has anyone installed aftermarket exhaust systems without rejetting?I am installing a Jardine system and dont want to rejett.Was wondering if the bike would still idle and run fine without rejetting.I am willing to give up a little performance gain to get out of rejetting.Any input would be helpfull.
brion b is offline
post #2 of 3 (permalink) Old 03-03-2007, 08:14 AM
MIKES86VULCAN's Avatar
I had a Jardine set put on my bike and runs great - if not better than before with my old stock without rejetting.
Mike B.
MIKES86VULCAN is offline
post #3 of 3 (permalink) Old 03-03-2007, 05:34 PM
93VN750's Avatar
No, stock jets unless you change the intake. Perhaps the mixture is a little richer with the aftermarket pipes due to the higher restriction going to 1:1 mufflers instead of the stock 2:2 setup.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
