balencer shaft replacement help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 07-07-2013, 06:33 PM Thread Starter
OK so if you frequent this part of the forum in another discussion I mentioned that I broke the head off the reverse thread bolt on the flywheel side of the balencer shaft. After putting the entire engine in a drill press, multiple attempts to weld a head on it I have given up on extraction.
Question. Do you have to split the crank case to replace the balencer shaft?
tgell001 is offline
post #2 of 22 (permalink) Old 07-07-2013, 06:40 PM
As I know it - yes...view it here
P/N: 13107-1146
http://www.cheapcycleparts.com/oem-p...750/crankshaft
There must be an Extraction tool for LH threads ! Worth the $$$ / Time
post #3 of 22 (permalink) Old 07-07-2013, 06:54 PM
Mcneuby's Avatar
Left Hand Extractor
Google it, You will come up with several options. They are available.
Mcneuby is offline
post #4 of 22 (permalink) Old 07-07-2013, 08:20 PM Thread Starter
I have a tap and dye set. Easier said than done. Even have a cobalt bit that does very little to screw, hole isn't straight (even when I put the engine under the drill press) cuz you have to press so hard the bit bows
I really don't know what else to do except replace the shaft or scrap the project all together.
tgell001 is offline
post #5 of 22 (permalink) Old 07-07-2013, 08:36 PM
Chucklehead
dragon159's Avatar
A self tapping bolt/screw would work as a left handed extractor. if you need a new shaft I have one from my parts motor yet.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #6 of 22 (permalink) Old 07-07-2013, 09:04 PM
Concert connoisseur
wib714's Avatar
Im at this point too, got the covers off, gaskets cleaned off just need to pull the rotor and gear over the balancer I believe, but the thought of renting the pullers and chance busting a bolt I'm tempted to put the covers back on and fix the oil leak I pulled the engine for in the first place and ride it till it slings a balancer through the case. it was not vibrating nor did I have chunks in my oil. any thoughts?
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #7 of 22 (permalink) Old 07-08-2013, 04:18 AM
gibbo's Avatar
Here are my thoughts. Yes you will need to split the cases to change the balancer shaft, but, it is quite straight forward. You also get to inspect the oil pump chain and with a little work you can inspect the oil pump rotors. you can also clean the sump and inside of the cases, replace the base gaskets (they can be suspect and leak coolant). You get to check the bores, pistons ,rings, main and bearings.You can inspect the inner gear shaft and all the gear shaft washers and circlips. You can inspect the water pump inner bearing. you only need a puller for the alternator rotor and a bolt will do that if you don't want to get the type you hammer round (I got the hammer round type from ebay, not expensive and worked beautifully ). They are not that complicated as motors go, do your homework and read the manual. You just need to be methodical and get the cam timing procedure straight in your head before put it back together. Trust me, once you have done it all you will feel very pleased with yourself and will have a lot more faith in your motor.
One can never have too many alternative forms of transport.
gibbo is offline
post #8 of 22 (permalink) Old 07-08-2013, 08:59 AM Thread Starter
Thinking about buying motor off ebay. They have one posted right now for like 800 with shipping out of a 95 w/ 11K miles on it. Then rebuilding the one i have now at my own leisure and either swapping out motors when i'm done or getting another bike w/ a blown motor and putting it in that. I just am afraid that a purchased used motor will have a bad head gasket too (or something else wrong) and i'll be right where i started and in the hole even deeper.
Just want this thing to be up and running dont have a ton of free time or money. Frustrated that my project came to a screeching hault because of this one epic mistake. Was going well too just prior haha
tgell001 is offline
post #9 of 22 (permalink) Old 07-08-2013, 09:15 AM
R/R = Relocated Redneck
Jakzen's Avatar
Like others have said, a standard RH bolt/screw works like an easy out on LH threads. If you're bowing the drill bit, it's either dull our just too small for the application. You might have better results using a bigger bit/tap combo. With hardened steel, unfortunately, you have to be patient and can't lean too hard on it.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #10 of 22 (permalink) Old 07-08-2013, 12:10 PM
get a good expensive bit that doesnt dull easy then drill slow with a lot of pressure once your hole is all the way thru the bolt spray pb blaster in the hole and wait ten mins then get a torx head bit and using a hammer drive it into the hole and with a bit of effort it should come out
i just did this with mine and it worked great
