Oil Light came on ! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 36 (permalink) Old 07-07-2013, 01:08 PM Thread Starter
Oil Light came on !
..........had my bike running yesterday, tweaking the carbs. With a weak Stator I do not ride over a mile before returning. While riding, the Oil light came on ! WTF ! Added 1/2 qt of Oil....no change.
I have not performed an Oil change ....shouldn't need to burp Oil filter or should I ?
It does have oil which drips occasionally from the bottom of radiator area. What is that ?
Used "Search" , for threads, but had no luck.
Help
post #2 of 36 (permalink) Old 07-07-2013, 01:19 PM
I would go for a burp first a foremost. You could have a clogged filter causing an air bubble as well?
I'm not sure about your leak, maybe it's just a small leak around the filter gasket.
post #3 of 36 (permalink) Old 07-07-2013, 01:26 PM
also check for a pinched wire from the sender to the light.. had that problem on mine.
michiganteddybear is offline
post #4 of 36 (permalink) Old 07-07-2013, 02:17 PM Thread Starter
OMG....I hope....I hope ....I hope !
I'll check ....thanks !
post #5 of 36 (permalink) Old 07-07-2013, 02:38 PM
Okiebezer's Avatar
I would definitely check out the sending unit. Clean it up and check wiring to it first.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #6 of 36 (permalink) Old 07-07-2013, 03:38 PM
since the sending unit in the grounding switch (if I recall) for the light, you can always pull the wire off it, and the light should go out (wont matter if engine is running or not). if it stays light, then you have a pinched wire or other short in the wiring
post #7 of 36 (permalink) Old 07-07-2013, 03:41 PM
bil it could be the oil sender not tight enough or the spark plug tube o ring
and that stator is not weak i only put 70 miles on it and we tested it when we started the bike it is putting out over 13 volts at 4k and 12.4 at 1k if those numbers have changed then i would be checking your solder job on the stator wires
and since you decided against replacing your balancer shaft even though the tip was all beat up that is the reason for your vibrations
i also informed you to change the oil after about 100 miles so you could get all the assembly lube out along with any of the silicone that may have broken free from the inside of the gaskets
and why are you still tweeking the carbs i had them right when you left here
post #8 of 36 (permalink) Old 07-07-2013, 04:28 PM Thread Starter
I'll check the oil sender not tight enough, as well clean that electrical connection.
spark plug canister O rings do leak a little, have not done anything with them yet. They have pretty much quit leaking.
I will check/Ohm out the Stator solder connections with Meter.
I have only put 100 miles or so on the bike total...maybe 120. No longer trust the Stator output/battery strength away from home. New MF AGM Battery Nov 2012.
Oil change coming this week.
Vibrations ? I have not experienced any vibrations in my bike.
Tweaked the carbs....reduced popcorn exhaust farts.
Those Coaster Enricheners = Carb Air Cut Off Valves ...I need to replace...occasional popping @ carb intake @ idle (also visible at clear vacuum hose on Front carb/petcock vacuum) - when cold.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
post #9 of 36 (permalink) Old 07-07-2013, 05:34 PM
oil change should fix it
post #10 of 36 (permalink) Old 07-07-2013, 06:24 PM
Chuck A.'s Avatar
we tested it when we started the bike it is putting out over 13 volts at 4k .......
That's way to low to keep the battery charged. Takes 13.5 to maintain a 12 volt battery without the head light and markers drawing volts.
Also, don't start the engine if there is a question of the oil supply. Pull the sending unit out, pull the spark plugs to take the compression off the pistons so the starter spins the engine freely, see if you get oil out of the sending unit hole. If not, Lord be with you. Dry bearings on a running engine go in a hurry.
Chuck A. is offline
