FYI- My engine noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-06-2013, 08:43 AM Thread Starter
JM2001's Avatar
Results to this thread
https://www.vn750.com/forum/showthread.php?t=33938
My noise problem was a result of a few things. What sounded like marbles being thrown around turned out to be insufficient lubrication to the cam chains in the front cylinder. I was using 20-50 motorcycle oil ( as usual ) and had 2500 miles on the oil. I drained the oil and put in a new filter. 90 % of the noise went away. I then added 6 oz of SeaFoam to the oil and drove 30 miles. I drained the oil, new filter, and put in 15-40 oil. No noise. Engine runs great. After putting in the 15-40 weight oil I did tighten up the MCCTs to quiet the engine more. Tightening the MCCTs is only 1/2 of the adjustment. Above the Cam Chain Tensioner is a chrome flange bolt. This flange bolt holds a spring, part number 92081-1380, which pushes against the upper chain guide. My springs were weak and replacing them quieted the engine more. A 5 minute install for both cylinders. Cost me $10.96 locally
http://www.kawasakipartsnation.com/o...ft-s-tensioner
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #2 of 4 (permalink) Old 07-06-2013, 09:06 AM
3Fan4Life's Avatar
Thanks for the info.
Mine begins to sound like a sewing machine if I run it over 70 mph for extended periods of time.
From what I've been able to find here, I felt like the ACCT's could be the problem.
Maybe, I will just try replacing the springs and see what that does.
I Corinthians 1:18
3Fan4Life is offline
post #3 of 4 (permalink) Old 07-06-2013, 09:13 AM
First I ever saw this spring as a problem/cure. JM -Thanks for the education - added to my wisdom bank. LOL
post #4 of 4 (permalink) Old 07-06-2013, 12:51 PM
You should put manual tensioners in, honestly. Fiddling with the ACCTs is fairly pointless; it's an inherently flawed design.
