doing engine work ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 06-30-2013, 01:15 PM Thread Starter
knees in the breeze!!!
Tofer76's Avatar
im going to be pulling the engine on the bike to do a stator job and balancers and i was reading some post on it
i noticed someone said to replace the water pump bearing?
is that prone to failure?
what does that entail and why mess w it if nothing is wrong ??
thanks
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #2 of 2 (permalink) Old 06-30-2013, 01:51 PM
I believe that also requires a case split, and the stuff you are doing does not. I wouldn't mess with it unless you have an actual problem. If I was splitting the case I'd do the shift shaft linkage, but only if I was splitting the case.
You can always pop off the other side cover and check the status of your water impeller and the mechanical seal behind it. If it doesn't look good replace them. I did (engine was still in the bike).
