Grambo trick - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-29-2013, 04:32 PM Thread Starter
bamafrankie
bamafrankie's Avatar
Grambo trick
My timing chains were making noise so I tried the grambo trick and it worked for me. But when I removed the bolt on the acct for the rear cylinder a little gas came out
bamafrankie is offline
post #2 of 7 (permalink) Old 06-29-2013, 07:05 PM
gas??? oil I would expect.
post #3 of 7 (permalink) Old 06-29-2013, 08:39 PM
If oil came out that's fine. It's meant to.
You should not see gas. If there is gas there, that means there is gas in your oil.
post #4 of 7 (permalink) Old 06-29-2013, 08:47 PM Thread Starter
bamafrankie
It had gas in oil when I got it petcock was bad. Drained and replaced oil and filter. Repaired petcock.
post #5 of 7 (permalink) Old 06-29-2013, 08:57 PM
Could have just been some leftovers that seeped into the ACCT then.
post #6 of 7 (permalink) Old 06-30-2013, 08:59 PM
Concert connoisseur
wib714's Avatar
think I'd do another oil change!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #7 of 7 (permalink) Old 06-30-2013, 09:06 PM
The ACCT for the rear angles downward a lot, and "catches" stuff....Id suggest just to remove the entire ACCT, clean it out inside with like WD40, and put it back on....run it, then take the cap off again...
