replacing Pickup coils - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 02-16-2007, 06:45 PM Thread Starter
The pickup coil for the front cylinder on my 750 opened this summer. Now its only running on the back cylinder. Do you really have to remove the engine as stated in the manual? How difficult are they to replace with engine still in bike?
SlaterVN750 is offline
post #2 of 8 (permalink) Old 02-16-2007, 07:07 PM
Uber Member
you will soon find that the books say remove the engine for everything....
Like on page 83 in the clymers, it says to change the oil start by removing the engine listed on page 45.....
But there are alot of stuff where the engine isnt needed to be removed.
1) remove the smaller outter stator side cover (this is the one with 3 screws, drain oil first)
2) determine your damaged pick up coil
3) splice into the wire with the new coil. make sure the wires are soldered together, and use a small gauge hi temp shrink wrap ( atleast the 180c kind with chem resistance).
4) reassemble
the high temp shrink wrap is needed and so is the solder, so no skiping those. If you dont want to do that, then yes an engine pull is needed...
how do you know its the pick up coil?
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 8 (permalink) Old 02-16-2007, 07:07 PM
Crobins365's Avatar
I think you only need to remove the gas tank and the plastic thingies up by the bars - the pickup coil is right under there and you shouldn't have any trouble getting to the plug wires. You'll see posted elsewhere the consensus that Clymer's has you removing the engine for everything - oil changes, adding air to your tires....
C
Crobins365 is offline
post #4 of 8 (permalink) Old 02-16-2007, 07:09 PM
Crobins365's Avatar
Pickup and ignition coils are the same, are they not? If not...<sigh>...I'd better go back and remove my engine one more time before re-reading the Clymer's.
C
post #5 of 8 (permalink) Old 02-16-2007, 07:14 PM
Uber Member
pick up coils are in with the flywheel. Igition coils are the coils that make the spark voltage. dont worry, i confused them untill i pulled my engine apart
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #6 of 8 (permalink) Old 02-16-2007, 07:16 PM
Crobins365's Avatar
Aha! Since I'm in no hurry to pull my engine any further apart than I already have, then I'll remain blissfully ignorant and not chime in on this discussion.
No, wait:now I have another question: There are two pickup coils running off the flywheel, one for the front, one for the rear?
C
post #7 of 8 (permalink) Old 02-17-2007, 04:35 PM
Uber Member
yep.... just be careful when working with them, they need to be in the right locations... otherwise your cyls will fire wrong...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 8 (permalink) Old 02-19-2007, 10:17 AM Thread Starter
Thanks for the info, I was not looking forward to pulling the engine. Once the weather warms up I will attempt the coil replace.
