Help I'm an idiot! Radiator coolent hose hookup! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-25-2013, 12:35 PM Thread Starter
Ok so I was replacing the engine on my vn750 and now I don't remember how the cooling hoses hook up if someone has a diagram or some pictures I'd appreciate it thanks!
alkash19 is offline
post #2 of 3 (permalink) Old 06-25-2013, 01:01 PM
gibbo's Avatar
I don't have a picture, but I'm sure someone will have. if it helps I can describe how it all fits. The two metal pipes that fit in the cylinder heads (with o rings) go to two rubber hoses that connect to the thermostat housing, long one to the rear, short curved one to the front. small hose goes from just below filler cap to the reservoir. Front end of thermostat housing goes to top of radiator, bottom of radiator goes to stub outlet from clutch side engine cover.
One can never have too many alternative forms of transport.
gibbo is offline
post #3 of 3 (permalink) Old 06-25-2013, 02:06 PM
JM2001's Avatar
http://www.kawasakipartsnation.com/o...8e7f9/radiator
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
