Oil change - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 06-23-2013, 11:54 PM Thread Starter
Lionheart's Avatar
Oil change
Well I'm about to change my oil just wondering what oil and weight every one suggest runs better in the vulcan. I know someone has probably asked this before but I couldn't find it sorry. I'd appreciate the input
Lionheart is offline
post #2 of 13 (permalink) Old 06-24-2013, 12:10 AM
Seriously dude, READ THE VERSES! Most of your answers can be found their.
Oil is about as personal as a condom is to a guy. To each their own. Popular consensus suggests Rotella T 15w-40. It's heavy duty diesel oil, cheap, and can be had by the gallon which fits perfectly into the bike w/o measuring. The VERSES will also reference several store brand oil filters you can choose from that will fit our bike.
I can't stress enough on how important it is to read through the VERSES and use the SEARCH function to help you find your answers.
post #3 of 13 (permalink) Old 06-24-2013, 12:43 AM
Rotella T is the way to go oil-wise I'd say. I go lazy and use K&N filters for the bolt they have for removal. The verses has a whole list of filters that you can use.
post #4 of 13 (permalink) Old 06-24-2013, 01:25 AM Thread Starter
Lionheart's Avatar
Yeah I'm going to buy the rotella t what size is the k&n filter or number
post #5 of 13 (permalink) Old 06-24-2013, 01:36 AM
• stock Kaw (big $$$) – part # 16097-1066 FILTER-ASSY-OIL 2003
• an auto parts store can cross reference another one for you
• Purolator Pure One Filter (PL14610) ~ "the best you can buy" ~ it's blue, so you might want to use black spray paint, several coats all at once, then let dry before mounting (Sherwin Williams part # 140-0514, Wrought Iron Black)
• Mobil 1 M 1-110, Champion
• Bosch 3323, Champion
• Wix (black), part # 51358
• K & N 202 (larger than most; also has a “nut” at the end for easier removal)
• Fram PH 6010a & 6017a (both are black; the first is a bit larger)
Fram = NOT !
post #6 of 13 (permalink) Old 06-24-2013, 08:51 AM
Okiebezer's Avatar
I used the Bosch filter with Rotella T 15W-40.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #7 of 13 (permalink) Old 06-24-2013, 09:26 AM
Oil thread? Again?
Guess its about time again.
After all it's been a whole 21 days:
https://www.vn750.com/forum/showthread.php?t=31417
LOL
Don't forget to ask what battery to use.....
post #8 of 13 (permalink) Old 06-24-2013, 09:27 AM
I personally use tusk oil filters and a good quality 20W-50 for summer time oil. 10w-40 for winter
its all about preference really
kenny
Merc
2000 Vulcan Drifter 800
Roadhouse classic 2 > 1 exhaust
Okie Smokie intake config
Changed jets
52K miles or so, always going up
Corbin Seat
Painted flat black winter '12
Mercury is offline
post #9 of 13 (permalink) Old 06-24-2013, 09:45 AM
Oil thread? Again?
LOL
The majority agree on Rotella T, so not much of an oil thread...
That being said, the most important thing is that the engine has oil. Use whatever floats your boat as long as it's OK to use with a wet clutch.
post #10 of 13 (permalink) Old 06-24-2013, 11:40 AM
The K&N I used is the 303, instead of 202 posted earlier. The chrome one is 303-c.
Running Rotella 15w40 in mine, I use straight 30w Rotella in some other equipment engines, it's good stuff.
