broken temp sender - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-14-2007, 12:27 PM Thread Starter
brand new old guy
cisco's Avatar
Unhappy broken temp sender
ok you know the sensor on the bottom of the radiator, yeah I broke it. I tried to rewire a switch, it draws (volts) way to much, put in a fuse, still draws(volts)way to much. So I'm thinking replace the sender. 80 freaken dollars is way to much for me. any Ideas????
I also think I'm running a little lean, that could be helping in the over heating deptartment. is there more then the one knob on the carb to help with the idle mixture, My engine has a tendancy to idle higher at hotter temps, and I'm always fumbling around with that nob. Help me gain my sanity.
cisco is offline
post #2 of 7 (permalink) Old 01-30-2007, 05:11 PM
fergy's Avatar
More than likely a hot engine idling faster is pointing to a vacuum leak. Especially if you think you're running lean (vacuum leaks cause lean running conditions) I'd be searching for a leak. If the hot engine seems to cause a vacuum leak, (and interestingly enough, lean conditions cause hotter running engines) it could point to your carb mounts, as the engine heats up, things expand and maybe a leak opens up with the expansion of parts... It's worth checking out.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 7 (permalink) Old 01-31-2007, 04:28 AM
Usually, (if my bike wasn't down for repairs) I would have to adjust the idle up a bit at first starting the bike and once it was warmed up I'd have to adjust it down some.
So, if it's not a major change in the idle rpm's (maybe 3-5 hundred or so), I'd say you're OK with adjusting till warmed up. (atleast for me, it's normal operating procedure)
As far as the sensor, WOW $80 !! You are talking about the fan sensor switch, right?
Ron Ayers has it for $71.60 shipping included. Still not cheap, but cheaper than $80.
post #4 of 7 (permalink) Old 02-05-2007, 01:34 AM
Ernie's Avatar
Send a message via MSN to Ernie
I can sympathise with you regarding the cost of replacing the sensor. The connector on mine corroded through & snapped off a year or so ago & it cost me around 45 (about $85). I often wonder how Kawasaki justify the cost of their spares. I was once told that they make little profit on the new bikes so they get the money back by cranking up the price of the spares. Don't know how true that is but i'm inclined to believe it.
I replaced the temperature sensor on my Volvo station wagon a couple years ago & it was a fifth of the price of the bike one - and that was at the main dealer!
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #5 of 7 (permalink) Old 02-05-2007, 02:11 AM
I think I'd believe that if the bike wasn't 20 years old.
After the first 5 maybe 8 years at very most, all the tooling for the thing had to have been paid for by profits made to that point.
Seems more like they know we need the parts, they know only they have them, so they know they can charge alot for them. Unlike auto parts, which have more than a few different companies that make aftermarket replacement parts, so the prices are cheaper.
Atleast that's how I see it.
post #6 of 7 (permalink) Old 02-08-2007, 10:03 AM
darrelc5's Avatar
Has anyone tried non-Kawa replacements? When I was looking for an adapter to fit my shop oil pressure gauge to the bike, the parts counter guy at the local Meryl's Auto Supply showed me parts book with about a zillion pressure sensors. They were categorized by pressure range and thread size, not just by application. I bet there's a similar book for temperature sending units.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #7 of 7 (permalink) Old 02-09-2007, 10:20 AM
darrelc5's Avatar
Hey! There's one on Ebay right now with a Buy It Now price of $12.50. See item number 280080085116.
Darrel
-Corbin Seat
-V-Force Windshield
-Brakelight Flasher
-MF Battery
-Headlight Relays
SOLD - 2013
darrelc5 is offline
