Need HELP with coastering. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 01-13-2007, 05:53 PM Thread Starter
Bartman's Avatar
I have installed coasters and need to know what to do with the extra hoses, the ones going to the valves I just took off, there is a small one going to one of the carbs and there is a big going somewhere.......what needs to be done with them????
thanks
Bart
Road Captain
SCRC Valdosta,Ga #274
VROC #19066
Wet Butt Riders #253355-2
PGR
Bartman is offline
post #2 of 13 (permalink) Old 01-13-2007, 06:10 PM
93VN750's Avatar
Bart -
If you removed the reed valves and put new plates over the holes, take everything from there back off the bike.
Only things you will have to do is get a cap for the vacumm port on the right (rear) carb, and plug the hose going into the air box from the vacuum valve (that you just removed).
Get ready to adjust your mixture screws.
You said you rebuilt and rejetted your carbs. What did you do to require a rejetting? Do you do an ear shave too? Exhaust?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 13 (permalink) Old 01-13-2007, 06:27 PM Thread Starter
Bartman's Avatar
that wasn't me that rebuilt the carbs........but the bike has been rejetted and has V&H cruzers.
you say get ready to adjust the mixture screws???
they have been turned out about 3 turns already.
Road Captain
VROC #19066
PGR
Bartman is offline
post #4 of 13 (permalink) Old 01-13-2007, 07:15 PM
93VN750's Avatar
Then you are probably going to be right there. Do you know what the carbs were rejetted with? Most people that install cruisers do not rejet.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #5 of 13 (permalink) Old 01-13-2007, 07:37 PM Thread Starter
Bartman's Avatar
Not sure was already done when I got the bike..........
I plugged both hoses put her back together and took her for a spin.......3-4000 rpm it began to run crappy........any ideas???
Road Captain
VROC #19066
PGR
Bartman is offline
post #6 of 13 (permalink) Old 01-13-2007, 08:07 PM
93VN750's Avatar
The only thing that has changed is that you coastered it? How about the carb vent hose, is that in a spot where it's not restricted? It's normally in a slot in the right ear. If it gets plugged, or partially restricted, you get a gas starve condition.
All carb vacuum ports accounted for?
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #7 of 13 (permalink) Old 01-13-2007, 08:25 PM Thread Starter
Bartman's Avatar
there is a hose by the right ear........but don't see a slot on the ear.......the only place I see is the 1 1/4X1 1/4 hole, is that where it goes???
Road Captain
VROC #19066
PGR
Bartman is offline
post #8 of 13 (permalink) Old 01-13-2007, 08:37 PM
93VN750's Avatar
See pic here http://tinyurl.com/y2he6c
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #9 of 13 (permalink) Old 01-13-2007, 08:55 PM Thread Starter
Bartman's Avatar
Hey Jon.......that was it, didn't have that hose in the right spot, she's running great now.
Thanks for your help
Bart
Road Captain
VROC #19066
PGR
Bartman is offline
post #10 of 13 (permalink) Old 01-14-2007, 09:09 AM
93VN750's Avatar
Bart
Bart -
Glad it worked!
How's it run with those Cruizer's? I just put MAC staggered tapered, same side exit pipes on mine and love them.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
