Changing radiator fluid. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 12-27-2006, 04:27 PM Thread Starter
MIKES86VULCAN's Avatar
Question Changing radiator fluid.
Hello,
Can anyone answer this question - I want to save some money and change my radiator fluid myself. I feel pretty comfortable draining the fluid but when I check the book it tells me to remove the gas tank and bleed the air. I really don't feel too comfortable about fooling with the gas tank and hope I could pass on that part. Suggestions?
Thanks... Mike
Mike B.
MIKES86VULCAN is offline
post #2 of 5 (permalink) Old 12-27-2006, 05:43 PM
HAWK
Ccspinner's Avatar
You don't have to remove the tank. If you run the bike with the radiator cap off that will ge the air out, thats what I did.
I also have a funnel that hooks up to the radiator cap and helps with this
Here is one on Ebay
http://cgi.ebay.com/Lisle-Spill-Free...QQcmdZViewItem
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 5 (permalink) Old 12-27-2006, 06:12 PM
93VN750's Avatar
In case you change your mind, its 3 bolts, a connector, 3 houses and your tank is off. Had mine on/off a few times today.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 5 (permalink) Old 12-27-2006, 08:49 PM
Now what
Ironman's Avatar
Originally Posted by MIKES86VULCAN View Post
Hello,
Thanks... Mike
I think taking the tank off just makes it easier to work the small air bleeder valve that sits on top of the thermostat housing. I've heard it can be opened and closed without removing the tank.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #5 of 5 (permalink) Old 12-28-2006, 01:10 AM
Uber Member
ehh i'd just remove the tank. as long as it isnt full, it take about 10 mins to take off and 15 to put back on. And to help bleed the hoses for the radiator, i learned a trick from a ford mech. Squeeze the hoses a lil untill the air bubbles come out. then run it and repeat..
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
