Oil screen suggestions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 12-12-2006, 11:37 PM Thread Starter
Drive less, ride more...
theauhawk's Avatar
Hey, everyone....!
My 750 is an '05, now with just over 3,500 miles on it.
I've seen some really good discussions/suggestions here about oil/filter changes.
But with this in mind, I was curious: along with using something like paint thinner to clean the oil screen, what other "dos" or "don'ts" can you offer about cleaning this screen?
Is a certain kind of brush to also be used when cleaning this screen? Or should one just soak the screen (say, for a few hours) in paint thinner, instead? Is another cleaning solution somehow preferable/better than paint thinner (e.g., gasoline)? Is cleaning this screen at every oil change a must-do, anyway? Is it much of a hassle to keep all of the screen's parts in their correct order/location?
Thanks for your feedback on the above....
theauhawk is offline
post #2 of 13 (permalink) Old 12-13-2006, 12:29 AM
Uber Member
i thought the screen was just there for particulates... i just rense mine under the old oil to clean out the particulates, then wash it with clean oil, then reinstall. and i do this as needed. but i check it atleast everyother oilchange.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 13 (permalink) Old 12-13-2006, 01:45 AM
Now what
Ironman's Avatar
Originally Posted by theauhawk View Post
Hey, everyone....!
I only look for chunks of balancer and abnormally large amounts of shaved metal. I also make sure the screen's still in one piece. It's not very sturdy so I don't use a brush on it. I haven't seen anything "melted" into it or anything particularily hard to get off of it. Just bits and pieces. Just give a shake in paint thinner, let it dry a little and it's good to go. After the first oil change (or major overhaul) it isn't necessary to pull it out each time, but it's a good idea. Again, if you find large chunks of black rubber for instance, the balancer could be falling apart. If it comes loose at speed, bang goes your crankcase.
It's not hard to put back in. Coming out is the drain plug, a spring, a large washer and finally the screen with the grommet attached. They all just slide back in the way they came out.
If I did ever find anything stuck to it, I'd soak it in SeaFoam overnight. That stuff dissolves lots of gooey things.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #4 of 13 (permalink) Old 12-13-2006, 05:09 AM
EDALBRIS's Avatar
the thread on 'oil screen colapse' may me useful to reed
https://www.vn750.com/forum/showthread.php?t=3026
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #5 of 13 (permalink) Old 12-13-2006, 11:23 AM
Sky Rider's Avatar
I just pick out the large particles and wipe it down with a rag and reinstall it all. I really haven't had much in it other than Permatex pieces that are flaking off from the gaskets. I'll never do that again!!!
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #6 of 13 (permalink) Old 12-13-2006, 01:20 PM
fergy's Avatar
I'd think checking this at every oil change would be a good idea, since it may be the only early warning system you have so some internal problems. I check mine every time. haven't found anything in it so far.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 13 (permalink) Old 12-13-2006, 01:39 PM
Sky Rider's Avatar
If you use the side drain method it is almost impossible to drain the oil without the screen falling out.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #8 of 13 (permalink) Old 12-13-2006, 02:27 PM
fergy's Avatar
Unless you're me! First time I changed my oil, it didn't fall out and I assumed there wasn't one in there and ordered a new one. Second time I poked my finger in there and out came the spring, washer and screen, all looking like new! so I conveniently have a bran new one with washer and spring in a box on my shelf in case I ever need them.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 13 (permalink) Old 12-13-2006, 02:38 PM
HAWK
Ccspinner's Avatar
I use brake cleaner to clean mine, you can get it in a spray can. Works great
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 13 (permalink) Old 12-13-2006, 06:57 PM
Sky Rider's Avatar
I like that a whole lot better than paint thinner.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
