Not another spark plug question... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 12-12-2006, 01:57 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
I will spare us the typical spark plug debate of iridium vs. typical.
But, I was wondering how often everyone pulls or changes their plugs. The plugs I have will last a long time, but I am afraid of seizing the threads if I don't pull them. However, on the other hand, pulling them yearly may crush the spark plug gasket and not let them seal like they should.
What are some experiences here?
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #2 of 10 (permalink) Old 12-12-2006, 02:50 PM
I haven't used the Iridium plugs yet, but any time I've removed the plugs, I've changed them.
If I did go with the Iridiums, I might consider using some hi-temp anti sieze.
post #3 of 10 (permalink) Old 12-12-2006, 03:13 PM
Uber Member
i change my plugs on my bike every 6-8k miles. i use regular old autolites.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 10 (permalink) Old 12-12-2006, 08:21 PM
I replace mine every year...copper auto-lites.
Imnohero is offline
post #5 of 10 (permalink) Old 12-12-2006, 08:34 PM
93VN750's Avatar
Definitely use anti-seize and you won't have any problems getting them out.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 10 (permalink) Old 12-12-2006, 09:13 PM
I've had mine out a few times when messing with the carb screws, always put a dab of anti-sieze on them just to be sure.
Woody is offline
post #7 of 10 (permalink) Old 12-12-2006, 10:00 PM
Sky Rider's Avatar
Anti sieze is the way to go though I've never had a plug sieze in either the bike or in any car I've ever owned when I haven't used the anti sieze. I use it now because it was recommended and I have a lifetime supply at this point. One bottle of the stuff goes a long long long long long way.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 10 (permalink) Old 12-12-2006, 10:06 PM
HAWK
Ccspinner's Avatar
Just be careful not to get Anti Sieze on the electrode, will cause a plug to fail early.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #9 of 10 (permalink) Old 12-13-2006, 10:40 AM Thread Starter
Benjammin'
BSkaggs513's Avatar
Good point, Chad. Thanks.
I have the iridium plugs I installed last year and was wondering if I needed to take them out yearly to keep the threads clear. I did put anti-seeze on the threads, but did not know if the stuff "disappeared" after some time. As I understand it, the plugs themselves should last a while, I just didn't want them to take out the cylinder threads on the bike when it become time to change them.
OK- I will put a "plug" in for the iridiums.....They are great.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
post #10 of 10 (permalink) Old 12-13-2006, 10:44 AM
93VN750's Avatar
You do not have to take them out, but sure can tell a lot about how the engine is running by having a look. Need to re-apply the anti-seize when you put them back.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
