Leak in Front of Front Cylinder - Help? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-10-2006, 09:34 PM Thread Starter
Crobins365's Avatar
Hi, everyone -
I think I found the culprit (ha ha - one of many) on my project bike: see attached pics. On the front cylinder, there are two holes on the front of the block, and it looks like I'm losing oil there. It also looks like maybe a leak in the gasket towards the rear of the cylinder, but I'm waiting to see what happens with that now that I've cleaned it off. As for the two holes in the front, I have a trace memory of a thread from about 6-8 weeks ago (maybe) where someone had similar probs (and some kind soul had diagnosed the problem and a possible solution). Can anyone help? Thanks!
C
Crobins365 is offline
post #2 of 8 (permalink) Old 12-10-2006, 09:40 PM
It looks a lot like mine did when the spark plug well o-rings were leaking. There is a drain hole to the front of the cylinder.
wwmkwood is offline
post #3 of 8 (permalink) Old 12-10-2006, 10:10 PM
Sky Rider's Avatar
It looks to me like maybe the valve cover gasket is leaking but it could be the spark plug well as well. The easiest way would be to clean it all off and then run the engine and see if you can trace where the oil is coming from.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 8 (permalink) Old 12-10-2006, 10:17 PM
It was bcjoker04 that tried plugging the sparkplug drain hole before it was determined that it shouldn't be plugged.
Originally Posted by bcjoker04 View Post
check it out here by clicking "View Post" ^^
post #5 of 8 (permalink) Old 12-11-2006, 07:14 AM Thread Starter
Crobins365's Avatar
Thanks, that's sounding familiar now.
Aside from just a lot of dirt and grime, the engine otherwise looks pretty good. I'm taking some comfort in that.... oh, and my newfound prowess at installing the ACCT springs!
C
post #6 of 8 (permalink) Old 12-11-2006, 07:32 AM Thread Starter
Crobins365's Avatar
Did you get replacement o-rings from Bike Bandit? I'm looking through their schematics and nothing's matching up. Quite. Any chance you have a part number? Thanks.
C
post #7 of 8 (permalink) Old 12-11-2006, 07:59 AM
EDALBRIS's Avatar
was the spark plug tight to undo on that side, as i have seen this caused by a slightly loose plug.
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #8 of 8 (permalink) Old 12-11-2006, 08:10 AM Thread Starter
Crobins365's Avatar
Good question. I haven't bothered to pull 'em yet, 'cause I had wanted to test my ACCT rebuilds. Then I just started yanking parts off yesterday so that I could see what in the world was happening there on the front cyl. Probably won't hurt to replace the o-rings in the retainers. Also, like Jon (93VN750), I'm gonna replace the hoses and clamps on the coolant system - as long as the engine's laid bare, might as well fix or replace what's accessible!
C
