Anyone Have Front Exhaust Manifold???? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 12-09-2006, 06:06 PM Thread Starter
93VN750's Avatar
Unless I can find a machine shop to drill out the stud that broke off in mine, I'll need a new front exhaust manifold.
Anyone have one they want to sell?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 12 (permalink) Old 12-09-2006, 07:43 PM
How much, plus shipping? Make a good offer and I'll send you one.
El_Taco is offline
post #3 of 12 (permalink) Old 12-09-2006, 07:53 PM Thread Starter
93VN750's Avatar
This'll be good....what do you call a "good" offer?
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #4 of 12 (permalink) Old 12-09-2006, 09:55 PM
Sky Rider's Avatar
A machine shop shouldn't charge more than about $25-30 I would think. It would take them about 20 minutes to remove the old stud and or retap the hole. A muffler shop did mine for $25 with retap.
A new manifold will run between $95-125 depending on whether it is the front or rear.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #5 of 12 (permalink) Old 12-10-2006, 09:34 AM Thread Starter
93VN750's Avatar
I agree that it SHOULD only be $25-30 even just to drill out the old one. The shops around here charge for the time they talk to you too. If I had a drill press with the right carbide bit, it's be done.
I think I am going to have to drill the hole and use a nut/bolt combo as I have already dinged into the thread area with my drilling attempts.
Going to try a machine shop tomorrow, new one is $95 from RA. Last resort.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #6 of 12 (permalink) Old 12-10-2006, 10:00 AM
I could send ya a carbide drill, or ball nose endmill if ya want.
post #7 of 12 (permalink) Old 12-10-2006, 10:04 AM Thread Starter
93VN750's Avatar
Thanks, that's a great offer I may take you up on.
Do you think a Cobalt bit could do the job? If so, I may one up at Sears today and try it.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #8 of 12 (permalink) Old 12-10-2006, 08:44 PM
Jon
I was thinking along the lines of $25-30 packaged and shipped. Didn't know they were so expensive new.
El_Taco is offline
post #9 of 12 (permalink) Old 12-10-2006, 08:54 PM Thread Starter
93VN750's Avatar
Dave -
Hold that thought. I may have a line on a bunch of stuff from a guy parting out a 750.
I will know by Wednesday.
If he does not have an exhaust manifold as part of the deal, $ 25 - 30 you suggested is cool.
Does it have good studs?
Thanks,
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #10 of 12 (permalink) Old 12-10-2006, 09:28 PM
Jon
Sorry I missed this earlier. Cobalt should work fine.
What I'd suggest (though it may be a little late now) is to start with a small (1/8") drill, doing your best to get it drilled on center. Then work up in drill size.
I'll get a few carbide drills together and ready to send, incase your other options don't come thru.
Helicoils would probably be a good fix on this, more so than with the oil plug thread repair brought up awhile ago.
