Okay, so I broke an exhaust stud bolt..... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 12-03-2006, 05:51 PM Thread Starter
93VN750's Avatar
I was able to get the nut off so I could remove the exhaust. Now that the engine is out I thought I would work on that stud knowing it had to be replaced.
After soaking it with penetration oil for a few days, it snapped off when I tried to back it out with a small pipe wrench.
Whats the best way to remove the broken part from the exhaust manifold?
I guess I could drill all the way through and then use a nut/bolt combo instead of a stud.
Ideas are welcome.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 14 (permalink) Old 12-03-2006, 08:05 PM
Jon you could try and drill thru it and use an easyout, or if you have an old busted drill bit you could try and hold it firmly against the busted bolt and put the drill in reverse....I had that work b4
TrashLord is offline
post #3 of 14 (permalink) Old 12-03-2006, 10:35 PM
HAWK
Ccspinner's Avatar
They also make left handed drill bits. I have had them work also, drill in reverse and sometimes it will catch and back out the bolt.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 14 (permalink) Old 12-04-2006, 10:29 AM
fergy's Avatar
I assume you used pb blaster or liquid wrench to soak the bolt. I'd soak it some more with either. Pick up a set of screw extractors at Sears. Backwards drill bits basically. You might even be able to drill the center out (carefully) with a smaller bit then use the extractors. The heat of drilling the center out will help free up the stuck bolt.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 14 (permalink) Old 12-04-2006, 10:45 AM Thread Starter
93VN750's Avatar
You know about assume......only had WD40 on hand, I know doesn't work for that application.
I will pickup some PB Blaster and an extractor.
Thanks,
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #6 of 14 (permalink) Old 12-04-2006, 10:53 AM
fergy's Avatar
Well, I can't say that using pb blaster would have kept that from happening, but it sure would have given you a better shot at it.
I replaced the suspension on an older jeep two years ago. Two days before, I sprayed every bolt and nut that was going to be removed with pb. I let them soak then hit them again the night before the take down. Some of them were huge bolts that I had to use my 1/2" ratchet and a piece of pipe on the end for leverage, but every single one (all of them rusty as heck) came right off without a single problem. It was the first time I had ever used or even heard of pb, but everyone on the jeep forum said to use it. I was sold. Been using it every since. So far, 100%. (knock on wood!) Wish I had talked to you a week ago!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #7 of 14 (permalink) Old 12-04-2006, 12:34 PM
Sky Rider's Avatar
I did the exact same thing shortly after I got my Vulcan. I tried drilling it out from the back side of the exhaust manifold and then retapping the threads. I ended up breaking the tap off in the hole and that was a real pain.
The solution was to take it to a muffler shop where they heated the tap to red hot and then gave it a good whack with a punch. It shattered and they were able to finish retapping the hole. It cost me about $25 but I got the manifold back and it is in use today. I bought generic studs for it and used anti sieze upon reassembly.
Be careful if you use the Easy Out or reverse drill method of getting it out because if you break them off in the stud and you can't get the pieces out, you will be faced with the same situation I had.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 14 (permalink) Old 12-04-2006, 12:46 PM Thread Starter
93VN750's Avatar
Thanks for the warning, I will hope for the best.....
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #9 of 14 (permalink) Old 12-04-2006, 01:32 PM
EDALBRIS's Avatar
Better Than Easy-outs (that Also Try To Expand The Bolt In The Hole Which On This Type Of Rusted In Bolt You Will Have To Use A Lot Of Force) Is The Splined Extractor , You Get A Drill Bit The Right Size And A Holder To Fit In The Socket Wrench And Most Kits Have A Guide For Drilling The Hole Central. Snap-on Do A Very Good Version Of This Type And If Your Going To Get It Out Without Drilling The Whole Thing Out And Retapping This Type Is Your Best Bet. Good Luck
P.s. Do You Know Anyone With An Oxycetaline Torch
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #10 of 14 (permalink) Old 12-05-2006, 08:10 PM
Loran in Npvl IL's Avatar
EDALBRIS,
Is this the kind of extractor you are talking about?:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Thanks
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
