Oil Strainer Colapse (prevention) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-24-2006, 07:47 AM Thread Starter
EDALBRIS's Avatar
A PROBLEM I FOUND IN THE EARLY 90's WAS THAT THE OIL STRAINER (GAUZE TUBE) WOULD COLAPSE AND RESTRICT OIL FLOW, OR COLAPSE AND RIPE OFF THEREFOR NOT PROTECTING THE OIL PUMP,CAUSE SEAMED TO BE COLD OIL OR CLOGGING FROM PARTICALS OF GASKET PASTE,BEARING WEAR,CAMCHAIN GUIDE WEAR THE USUAL.
I FOUND THAT EVEN WITH A WELL RUN IN ENGINE AFTER MANY OIL CHANGES USING THE RIGHT OIL THIS COULD STILL HAPPEN.
I NOW USE A COMPRESSION SPRING INSIDE THE OIL STRAINER SAME DIAMETER AS INTERNAL OF GAUZE ABOUT 3/4"(17mm) AND ABOUT 3"(75mm) LONG, I HAVE NEVER HAD THIS PROBLEM AGAIN.
HOPE THIS IS USEFUL TO SOMBODY.
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #2 of 6 (permalink) Old 11-24-2006, 08:16 AM
Good tip Edalbris !
I'll have to do that on my next oil change.
I totally forgot to look at the strainer at my last oil change.
post #3 of 6 (permalink) Old 11-24-2006, 08:44 AM
Search Goddess
Dianna's Avatar
Because of their delicate nature it is suggested to replace them every 20,000 iles or so. Your solution may prolong that.
P.S. I have a few extras available in the parts dept. for $6 plus shipping
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 6 (permalink) Old 11-24-2006, 09:18 AM Thread Starter
EDALBRIS's Avatar
I Still Replace It At The Same Milage It Just Prevents Any Mishaps
EDALBRIS
EDALBRIS is offline
post #5 of 6 (permalink) Old 11-24-2006, 11:05 AM
wow 20,000 miles...mine only lasted 1,000...oh wait thats right dumb me stepped on it when I was doing the tear down
TrashLord is offline
post #6 of 6 (permalink) Old 11-24-2006, 12:36 PM Thread Starter
EDALBRIS's Avatar
A Point To Remember Is They Fail Like A Beer Can, If They Are Perfectly Round And Straight They Are Much Harder To Colapse, If They Are Bent Or Have A Dent In Them They Colapse Realy Easily.
So If Your Not Fitting A Spring Inside Be Very Carful Not To Distort Them In Any Way.
EDALBRIS
EDALBRIS is offline
