Grambo Trick Worked (with audio!) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 11-10-2006, 08:19 PM Thread Starter
fergy's Avatar
I started my bike this evening and shot some video holding the camera about a foot from the right side of the engine, let it run a little and shut it off. Then I did the grambo trick. See vulcan verses if you aren't familiar with this quick bandaid for noisy cam chain. It just unsticks the tensioners without removing them. Anyhow, after I did the grambo trick, I started up the bike and held the camera in exactly the same location. You can hear the difference on the sound clip. First half of the clip is before grambo, and you can hear the clicking very clearly. About half way through the clip, you'll hear the sound change. That's where I edited in the after grambo sound. Notice the clicking is gone. Cool! Now I can ride until my APE's come in!
http://pages.tstar.net/~fergy/images...hain_noise.wav
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #2 of 11 (permalink) Old 11-10-2006, 09:23 PM
Once Banned
cegodsey's Avatar
That's it! Just before halfway, it sounds like you revved the enging and made the sound go away. Or, you stopped and started recording again. In any case, the second half of the recording sounds like the sound isn't there. By design?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 11 (permalink) Old 11-10-2006, 10:17 PM Thread Starter
fergy's Avatar
It's two recordings bump edited together. You're right, just when I start to rev the engine the second time is when the edit hits and the second recording starts. I wanted it this way to be able to immediately hear the difference. It's subtle but it's definitely different.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #4 of 11 (permalink) Old 11-10-2006, 10:33 PM
Once Banned
cegodsey's Avatar
Well done. It is subtle, but if you crank your speakers a bit, you can definitely hear the tappity-tappity.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #5 of 11 (permalink) Old 11-10-2006, 11:52 PM
Uber Member
yeah... you can... tick tick tick tick.... gone.....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #6 of 11 (permalink) Old 11-13-2006, 03:14 PM Thread Starter
fergy's Avatar
My APE's came today. Freekin fast for priority mail from NY. I just ordered them Friday! Whew. Now I have to install them. Guess I'll be looking at the verses for directions!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #7 of 11 (permalink) Old 11-13-2006, 07:16 PM
Uber Member
lol... did they not come with them? There was a post on here not but a week ago stating how to adjust them. i'd link ya but for some reason my links never seem to work lol. tell me how they go, cause if my new springs dont work, i will be moving to the apes...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 11 (permalink) Old 11-14-2006, 10:00 AM Thread Starter
fergy's Avatar
Well, there's like two sentances on the back of the package. I asked Dianna since she has them and it's an easy job. Directions are here in the verses: https://www.vn750.com/forum/showthread.php?t=1079
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 11 (permalink) Old 04-05-2009, 07:45 PM
Jace Bror's Avatar
OK I did the grambo trick today, after doing it realized they weren't making that much noise to start with. But anyhow, is it normal for some oil to come out of there, especially the rear cynlider?
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #10 of 11 (permalink) Old 04-05-2009, 08:25 PM
It is normal. Some say that the front acct needs more oil, that the lack of oil is the reason that it goes bad.
