Coolant System Pressure Tester to borrow... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 11-06-2006, 02:36 PM Thread Starter
93VN750's Avatar
Does anyone have one of these that I can borrow? All of the rentals places here do not carry them. They're like $ 130 new. Would gladly pay the freight back and forth.
Something like this http://stant.com/brochure.cfm?brochu...ocation_id=183.
Jon
93VN750 is offline
post #2 of 11 (permalink) Old 11-06-2006, 02:43 PM
I had one several years or more ago, but the guy that used it last never returned it, and I think he's since moved outta state
Have ya tried a Mom & Pop type bike repair shop? Maybe they'd let ya use it yourself right at their shop.
post #3 of 11 (permalink) Old 11-06-2006, 02:46 PM Thread Starter
93VN750's Avatar
Problem is, you have to remove the gas tank to get to the radiator cap.
Need to do it in the garage. If need be, I'll buy one on ebay and others here can borrow if needed.
Jon
93VN750 is offline
post #4 of 11 (permalink) Old 11-07-2006, 01:49 PM
Ernie's Avatar
Send a message via MSN to Ernie
I made a pressure tester a few years ago for my car. Got an old radiator cap from a scrapyard, removed the spring & relief valve then drilled a 3/8" hole in the middle & put a tire valve in there. Made a rubber seal for the underside of the cap to stop any air escaping. I could then pump up the system with a bicycle foot pump & look for leaks. All it cost me was a 1 donation in the scrapyards charity box for the old radiator cap. Used an old tire valve I had in my workshop. Would be just as easy to make one for a bike as long as you can get hold of a secondhand cap of the correct size.
A lot cheaper than buying one from a workshop supplier.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #5 of 11 (permalink) Old 11-07-2006, 01:56 PM Thread Starter
93VN750's Avatar
That's very creative. Found one on ebay delivered for $20.
I'll have one if anyone needs it.
Jon
93VN750 is offline
post #6 of 11 (permalink) Old 11-08-2006, 10:33 AM
2FAS4U
Sorry for the delay. You can get a loaner at Autozone. # AZ9300
2fas4u is offline
post #7 of 11 (permalink) Old 11-08-2006, 10:41 AM Thread Starter
93VN750's Avatar
Funny enough when I called Autozone, they said they din't have one. Go figure.
Thanks though.
Jon
93VN750 is offline
post #8 of 11 (permalink) Old 11-08-2006, 05:09 PM
Uber Member
did u try orileys? i know they lend tools too
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 11 (permalink) Old 11-08-2006, 05:41 PM
HAWK
Ccspinner's Avatar
Jon
Why do you have to remove the tank? I can get my Radiator cap off by removing the side cover in front of the tank.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 11 (permalink) Old 11-09-2006, 08:15 AM Thread Starter
93VN750's Avatar
The tester is somewhat bulky and I don't think it will clear with the tank in place. I will try it first and see.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
