Should I replace my head gaskets too...... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 11-05-2006, 09:21 PM Thread Starter
93VN750's Avatar
My stator has officially checked out. I know I could replace the stator without pulling the engine, but, I suspect a head gasket problem dur to mysterious coolant consumption that I can't contribute to anything else.
I figured since I could pull the motor for the stator, could also polish up areas not possible when on the bike, and, replace the two head gaskets at the same time. They are only about $ 25 each, perhaps a worthwhile investment?
Yes? No?
Jon
93VN750 is offline
post #2 of 7 (permalink) Old 11-05-2006, 10:26 PM
Once Banned
cegodsey's Avatar
Um, OK.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 7 (permalink) Old 11-05-2006, 10:48 PM
HAWK
Ccspinner's Avatar
If you feel confident in doing it go for it. Are you talking the top headgasket or the bottom of the jug?
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 7 (permalink) Old 11-05-2006, 11:14 PM
Uber Member
Yes? No?
Jon
sorry but unless you have a modded stator cover, there isnt a way to get in there to replace it without removing the engine....
polishing is always good. on the head gasket....i dunno, plus at that price that sounds like it is the lower one, not the upper
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 7 (permalink) Old 11-06-2006, 02:48 AM
Once Banned
cegodsey's Avatar
Well, you don't have to pull the engine, more like move the engine.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 7 (permalink) Old 11-06-2006, 08:07 AM Thread Starter
93VN750's Avatar
I meant for stator only, I could "shift" the motor rather than pull it. I figured that the head gaskets require a complete pull so I could tackle them both at once.
I would hate to do the stator, then find out the problem is a head gasket and have to pull in again.
Jon
93VN750 is offline
post #7 of 7 (permalink) Old 11-06-2006, 08:14 AM Thread Starter
93VN750's Avatar
I was thinking of only the top one, but, I suppose either one could cause a coolant leak?
Jon
93VN750 is offline
