Manual Cam Chain Tensioners Too Long. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 11-04-2006, 10:37 AM Thread Starter
dta116's Avatar
Has anyone installed the Manual Cam Chain Tensioners from Schnitz Racing?
I tried this weekend and they work fine with one exception, the rear tensioner bolt sticks out too far to reinstall the coolant reservior.
Does anyone else have this problem?
dta116 is offline
post #2 of 3 (permalink) Old 11-04-2006, 11:08 AM
Search Goddess
Dianna's Avatar
The rear cylinder seems to be the problem and here are a couple of solutions..
"the only thing is i had to make a small spacer and go with a longer bolt to move the coolant tank back a bit so it didn't contact #2 cylinders tesioner bolt ."
or..
One problem is they are to long. The coolant reservoir will not fit without cutting the adjustment bolt off. I sawed off the bolt and will replace the end with an acorn nut. I have taken a lot of digital pictures. How do I post the pictures here?
https://www.vn750.com/forum/attachmen...4&d=1115730343
https://www.vn750.com/forum/attachmen...5&d=1115730353
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 3 (permalink) Old 11-04-2006, 03:28 PM Thread Starter
dta116's Avatar
Thanks Dianna, I shimmed the coolant tank, I think I like that solution better, I may try the saw during the summer when the weather is nicer.
dta116 is offline
