Freeze plugs, anyone? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-30-2006, 05:55 PM Thread Starter
I looked through every page here, and found no mention of freeze plugs, or at least nobody's seen a problem. I pulled my radiator, mostly because I wanted it out of the way, and because there was flaky crap in every hose I've pulled.
City water does a number on aluminum. As I was blowing the flaky crap out, I noticed a hole behind the perch for the RH foot peg. Is there supposed to be a glass here, or some kind of expansion plug?
El_Taco is offline
post #2 of 12 (permalink) Old 10-30-2006, 08:19 PM Thread Starter
I had a look at the parts motor. There's supposed to be a plug in there, alright. It was flush with the case and smooth across tht top. It was actually an access hole for a fastener for something. Anyone ever seen one of these missing?
El_Taco is offline
post #3 of 12 (permalink) Old 10-30-2006, 09:34 PM
Once Banned
cegodsey's Avatar
I see it! Smooth to the engine. So you say it's an access hole? What for? Have you looked at the parts microfiche? It appears to be an oil seal and ball bearing behind that plug, from what I can tell. Seems like Kaw only figured the left side of the engine was important, so it's hard to tell.
You do have the shop manual PDF file don't you? Somebody have the link? I don't appear to have it, although I have the 110+MB PDF file.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #4 of 12 (permalink) Old 10-31-2006, 08:43 AM
Search Goddess
Dianna's Avatar
Forget about the plug, did you say.. City water?
I hope that was the previous owner that thoughtlessly put city water in the radiator!
Always. ALWAYS use distilled water if you are mixing the coolant. Mineral deposits are the results if you don't. Same for the battery if you are still using a wet cell.
Chances are those flaky deposits are in the radiator too and not just the hoses.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 12 (permalink) Old 10-31-2006, 05:27 PM
Once Banned
cegodsey's Avatar
I always use the water from the dispensers in downtown Hot Springs. That way I'm sure it doesn't have chlorine or flouride in it.
Dianna, what's the link for the Manual PDF?
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 12 (permalink) Old 10-31-2006, 05:38 PM
fergy's Avatar
I'm sure you're kidding right? That would be "mineral water" which is exactly what you don't want.
http://www.tocmanufacturing.com/File...nd%20Parts.pdf
It's a biggie, so it takes plenty of time to download!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 12 (permalink) Old 10-31-2006, 07:25 PM
You guys really should drain your radiators and put in fresh antifreeze and DISTILLED WATER like Dianne suggests you really dont need deposits in your colling system............
Krawdad7 is offline
post #8 of 12 (permalink) Old 10-31-2006, 08:21 PM Thread Starter
I may try to get a picture. It's just a nut, which is recessed about a quarter inch.
And the easiest way to go is pre mixed 50/50.
Thanks for the file. Our computer is down. I'll have to download it after the reformat.
El_Taco is offline
post #9 of 12 (permalink) Old 10-31-2006, 09:40 PM
Once Banned
cegodsey's Avatar
Yeah, kidding. But I do use tap water. Have been all my life. Battery too. Yeah, I know you're sposed to use distilled, but I don't keep distilled handy.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #10 of 12 (permalink) Old 11-01-2006, 12:32 AM
Search Goddess
Dianna's Avatar
Pfffft.. With the bike you don't have to.. IF you have a maintenance free battery and buy the pre-mixed coolant
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
