Engine cutting out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 08-04-2004, 06:19 PM Thread Starter
Engine cutting out
I had a problem with my engine cutting out under load. At first I thought my clutch was slipping. Well yesterday I noticed one of the holes in the airbox that is for the hose that goes to the mushroom was open. I had it plugged with duct tape. As soon as I sealed that hole back up the cutting out went away. Apparently duct tape does not like heat. I used two rubber plugs from Advance Auto to block the reed valves. Mike '89 vn 750
mnmkiller is offline
