need engine info for mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 10-18-2006, 07:11 PM Thread Starter
Uber Member
I need to know a few things. i figured i woul ask here first before getting told byt he local kawa dealer that i should just buy a bigger bike lol
i need to know the fireing sequence of the jugs in refference to rotations of the crankshaft.... I.e. cyl 1 at top dead center about to enter combustion stoke is 0 deg... when does cyl 2 fire, 270 deg's later? then cyl 1 again at 450 degs later?
also does any one know if our ignition system triggers at the leading or trailing edge?
and also if anyone could shed some light on the duration of the cam, and size of the valves that would be great....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #2 of 18 (permalink) Old 10-18-2006, 09:34 PM
Sky Rider's Avatar
Do you have the shop manual??? I believe most of the answers to your questions are in there.
I'll check my Clymer's as well and get back to you.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 18 (permalink) Old 10-18-2006, 10:33 PM
Sky Rider's Avatar
I just looked in both the manuals I have and although it gives cam lobe height, it doesn't give a duration. I also can't find the timing sequence. All it says is that it is IC controlled and no adjustment can be made. I do know that it's supposed to fire 5 Degrees BTC. The front cylinder fires first and I believe the rear would indeed fire 270 degrees later. The valve sizes are:
Intake, Outside diameter, 30.9-31.3mm
Exhaust, Outside diameter, 26.9-27.1mm
I'll have to dig deeper for the rest.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #4 of 18 (permalink) Old 10-19-2006, 01:33 AM Thread Starter
Uber Member
he he, it will no longer be IC controlled.... the EFI unit i want to install also can control the ignition timeing very well. You can program it to adjust the spark on several factors from temp, rpm, load (map sensor), and throttle position. I cant wait... i guess when i do my cross over, i can always set up the igniton controler up to a dummy model and see...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #5 of 18 (permalink) Old 12-02-2006, 11:17 AM
EDALBRIS's Avatar
Depenting On How You Setup Your Cams You Can Have Her Firing
0 Then 90, Or 0 Then 270, I Preffer 0 Then 90, Makes For A Bigger Thump And Sounds Better.
P.s. Do Remember That The Std. Ic Rev Limiter Is About 8500rpm To Protect The Hydraulic Lash Adjusters.
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #6 of 18 (permalink) Old 12-04-2006, 01:07 AM Thread Starter
Uber Member
wouldnt u have to change the ignition somehow?
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #7 of 18 (permalink) Old 12-04-2006, 08:25 AM
EDALBRIS's Avatar
no vn uses wasted spark so fires on EVERY TDC on BOTH cylinders
ignition pickups are on alternator rotor and 1:1 with crank not 1:2 like a car distributor
EDALBRIS
EDALBRIS is offline
post #8 of 18 (permalink) Old 12-04-2006, 07:12 PM Thread Starter
Uber Member
humm... well i know it is wasted spark, just for some reason i though that the timing may have to be adjusted..... anyway. have you changed to the 0-90 set up? how is the vibration? power curve? does the flywheel have enough mass?
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #9 of 18 (permalink) Old 12-05-2006, 01:03 PM
EDALBRIS's Avatar
YES, MAKES IT MORE THUMPY DOES NOT EFFECT CRANK BALANCE SO VIBE NOT A PROBLEM.
HAD A LOOK AT MY OLD SCRIBLINGS LAST KNIGHT AND IT IS ACTUALY
0 THEN 60 OR O THEN 420AS THE VN IS A 60 DEG. V
SO STD. IS No.1 AT 0 DEG. No.2 AT 420 DEG. No.1 AGAIN AT 720 DEG.
NON STD.IS No.1 AT 0 DEG. No.2 AT 60 DEG. No.1 AGAIN AT 720 DEG.
EDALBRIS
EDALBRIS is offline
post #10 of 18 (permalink) Old 12-05-2006, 03:16 PM Thread Starter
Uber Member
can you PM me your cam specs so i can get a quote on getting some machined?
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
