Oil & Filter question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 38 (permalink) Old 10-15-2006, 01:19 AM Thread Starter
Wink Oil & Filter question
Today I was in Target and saw Castrol 4T 10W40 regularly priced @ 4.98/qt for sale at clearance price of 1.17/qt. Grabbed 4 without thinking much. however couldn't find any referrences to Castrol 4T in here or on BITOG site. Has anyone used it before....
Also the Purolator filter guide in Pepboys suggested to use ML16817, however I have read here to buy PL14610. Any reasons for not to go with ML16817? Or what are additional benefit of PL14610. Pepboys had a special of Purolator filter @ 99 cents which expired on Saturday. But you can still get some $3.5 Mail in rebate so the cost will come to about $6 -$7 dollars.
Also has anyone used the Mobile1 oil filter. What is the part number for our VN 750.
B K R is offline
post #2 of 38 (permalink) Old 10-15-2006, 04:23 AM
Once Banned
cegodsey's Avatar
What is 4T? What does Castrol say about it?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 38 (permalink) Old 10-15-2006, 06:44 AM
bunky1024's Avatar
The Purolator ML16817 is not actually made by Purolator and is not recommended for our bikes.
The two Purolator filters to use are PL14612(2.5 inches long) and PL14610(3.25 inches long), the longer is recommended.
Mobil-1 has the M1-108(2.5 inches) and M1-110(3.25 inches).
I used the Mobil M1-110 my last oil change, 1300 miles ago and have had no problems.
Greg
Chicago, IL
2003 VFR800
1986 VN750A2
Mustang Seat
Iridium Plugs
K & N Air Filter
Spitfire Shield
Highway Pegs(Ccspinner's)
bunky1024 is offline
post #4 of 38 (permalink) Old 10-15-2006, 10:03 AM
Geek
rnewell's Avatar
I have Castrol GTX 10/40 in the bike now. The filter I just get from the local Kaw dealer.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #5 of 38 (permalink) Old 10-15-2006, 05:42 PM
Dan
I have no idea what "4T" means, but I have been using 10-40GTX for years. I change every 2500-3000 miles and get a filter from my Kawasaki shop. The used oil always looks pretty clean when I dump it out; maybe I'm changing a little too often(?)
Dan is offline
post #6 of 38 (permalink) Old 10-15-2006, 09:29 PM
Benjammin'
BSkaggs513's Avatar
Oil....(and filters)
I looked into getting a filter for my bike on my last oil change and found the Walmart version of SuperTech to be recommended by several folks from Vulcan sites for our bikes. I bought a filter and was just ready to screw it on, but decided to look inside it and compare it to what I pulled off my bike (a kawasaki OE filter). What I saw was no internal check valve inside the SuperTech filter. It is claimed to filter more materials out of the oil than OEM, but I would think the check valve would help lubricate the bike on startups and cause less internal damage. The Kawasaki filter is more expensive, but I will pay the few extra bucks knowing my bike's oil is being filtered and flowing the way it was intended.
Now, as far as oil goes, the following is a very informative link that evaluates many kinds of oil as well as filters;
http://motorcycleinfo.calsci.com/Consumables.html
Good luck.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #7 of 38 (permalink) Old 10-16-2006, 01:29 PM
Sky Rider's Avatar
I use the Shell Rotella T 15W-40 dino oil and the Bosch filter. No oil related issues.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 38 (permalink) Old 10-16-2006, 01:42 PM
Why not? I've had that filter installed on my bike for the usual 3K miles, no issues that I can see.
GreenJello is offline
post #9 of 38 (permalink) Old 10-17-2006, 08:11 AM Thread Starter
I couldn't find the 4T info on castrol website. Here is pic of the box. As you can see it doesn't have the circle saying whether it is energy conserving or not.
B K R is offline
post #10 of 38 (permalink) Old 10-17-2006, 08:18 AM
I think the 4T refers to it being 4 stroke motorcycle oil, because they have a 2T oil that is for 2 smokes.
