Valve noise from my '04 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-11-2006, 12:44 PM Thread Starter
Hi everybody,
I have an '04 570 with 22k miles that runs great. When I bought it this last summer, there was a lot of noise coming from the valve train. I rewound both ACCT's per Gypsy's instructions which fixed that problem. However, I have a tinny sounding tapping between 2 and 3k rpm coming from the top of the rear cylinder. Any ideas??? Is there anyway to adjust the valves or do I need a rebuild? Has anybody done this at home?? Thanks for your help!
Veneer
veneer is offline
post #2 of 6 (permalink) Old 10-11-2006, 12:52 PM
The Valves are hydraulic, so shouldn't need any adjusting.
It is possible you need to replace the ACCT springs. This can be a little tricky, but it can be done by yourself.
Have you had the oil changed recently? Fresh oil might help if you haven't.
Also, are you sure it might not be something else vibrating that is making the sounds you hear? Loose exhaust heat shields can cause a tinny sounding noise.
Oh yeah, Gypsy's site is available HERE, minus alot of pics and possibly some more recent updates
post #3 of 6 (permalink) Old 10-11-2006, 03:13 PM
Uber Member
i have the same tinny sound tapping...just mine is at all rpms. tried the grambo trick, worked for a ride or 2 and the sound is back, gonna try and rewind the springs with more preload sometime soon.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 6 (permalink) Old 10-11-2006, 08:00 PM
HAWK
Ccspinner's Avatar
I have the same sound. Just got my new springs today from TOC. Will let you know how they work.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 6 (permalink) Old 10-11-2006, 09:40 PM
Maybe its your set of house/car keys rattling around in your toolbox on the back of the seat.
Don't even ask me how I know that???? *^&%$#%&^
JohnBoy750 is offline
post #6 of 6 (permalink) Old 12-02-2006, 11:37 AM
EDALBRIS's Avatar
The Hydraulic Lash Adjusters Do Get Air In Them,(car Ones Auto Bleed The Vn's Ones Do Not) Which Can Cause This Type Of Noise, The Manual Shows How To Bleed Them, But You Don't Need The Special Tool They Show You Can Do The Same With A Darning Needle Stuck In A Cork. Or How Kawasaki now Sugests, Which Is To Stick 'slick 50' In Your Engine And Once The Engine Is Warm Hold It At 3000rpm For Three Minuts (it Works Fine).
It Could Also Be That If You Manualy Adjust Your Cam Chains They May Have Been A Bit Tight And The Cam Jurnals Have Worn Causing Them To Tap Up And Down As The Valves Are Pushed(i Hope Its Not This)
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
