question about ACCT - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 43 (permalink) Old 09-30-2006, 06:05 AM Thread Starter
question about ACCT
my acct's do not look like normal, I am wondering if it is possible that 1 of the previous owners turned the stock acct's into manual ones. they are the stock housings but have a bolt running through (and it sticks out about 1-1 1/2")with a stop nut on them also, and from what I have seen this is not what the acct's look like.
1) is it possible to change the acct's into manual cct's using the stock housings??
2) if 1 is a yes then why spend the $$ on the manual cct's?
the kid is at a friends for the night when she gets home I will TRY to post a pic of what they look like
TrashLord is offline
post #2 of 43 (permalink) Old 09-30-2006, 06:37 AM
Once Banned
cegodsey's Avatar
You can't post a pic without the kid?
1. Yes. That is what Gypsy did, or something very close. Hers required welding. I'd like to see the pics. You have to have manly talent to build your own MCCTs. I'm not manly enough.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 43 (permalink) Old 09-30-2006, 06:52 AM Thread Starter
no I can't post a pic without the kid...because I like the real camera's that use film, she has a digital and I would need to first download the disc on this puter (something I haven't wanted to do b4...dont want my puter loaded down with pics.
but you say Gypsy did this? and welding? the outside are stock, the welding is for the bolt once it is put thru the housing then I would guess.
post #4 of 43 (permalink) Old 09-30-2006, 06:59 AM
Is it possible to drill them out and put a 1/4" bolt thru it with two nuts, and just put a neoprene washer between the first nut and the housing to stop oil from leaking?
Just curious, cause the front one is bad on mine. I looked into the manual ones at tocmanufacturing.com but they are not available yet.
racohoon is offline
post #5 of 43 (permalink) Old 09-30-2006, 10:21 AM
Search Goddess
Dianna's Avatar
Since my bike is the beta tester for TOCManufacturing I can say leave the manual one there!
I played with the ACCT, doing the reset thingy and even replaced the springs with the beefier springs during a rebuild. I much prefer the manual ones.
Set em and forget em.
The actual housing for either are about the same, the 2 bolt base and if you do want to replace the manual ones with the ACCT you can with no problem.
In fact if you want to trade the manual one for an ACCT I'll trade ya!
http://www.sudco.com/apeCamchain.html
One little tip for the MCCT. I placed a small strip of teflon tape between the MCCT body and the lock nut to stop the small drip of oil that tries to work it's way up the bolt thread.
Credit to gypsy for her modification but do you really want to trust your cam chains to a home weld?
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 43 (permalink) Old 09-30-2006, 02:57 PM
Uber Member
hey how much are those apes'?
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #7 of 43 (permalink) Old 09-30-2006, 03:23 PM
Search Goddess
Dianna's Avatar
Sudco - Order #875.416 KT1100 TENSIONR $52.00
http://secure.cartsvr.net/catalogs/c...showprevnext=1
KT1100 Kawasaki - 1000 J Model, GPz1100, 600RR Ninja all, ZX-7 thru 90 (center cam chain) $44.95
http://www.z1enterprises.com/detail.aspx?ID=371 $50.35
http://www.skracing.com/Products/ape.htm
KT1100 APE Billet Cam Chain Tensioner Kawasaki J Model 44.95
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 43 (permalink) Old 09-30-2006, 10:39 PM Thread Starter
well forget about the pic for now (she left the camera at her other house)
as for changing manuals for auto's that was not in my post, the ape cam chain tensioners and the stock acct's housings are only similar in that they both use 2 bolts, mine are the stock housings only difference is that the bolt runs through with a stop nut. I'll just yank them tomorrow to find out ( suppose to rain so no riding anyways)
and would I trust my cam chains to a home weld? if it was my weld then YES I WOULD
post #9 of 43 (permalink) Old 09-30-2006, 10:49 PM
Search Goddess
Dianna's Avatar
I mentioned the home weld because I saw the picture of gypsy's ACCT mod.
ummmm.. well it was NOT the cleanest weld I've seen, especially for one to be used for a cam chain tensioner.
Your expertise however is probably different *S*
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #10 of 43 (permalink) Old 09-30-2006, 10:56 PM Thread Starter
Dianna do you have a pic of Gypsy's mod??
because like I said my tensioners are the stock housings but theres a bolt running through with a stop nut.
